If I'm understanding correctly...If you want to populate data from the UD table into the Part Table I would call to the Part Adapter from the form you fill in the UD information and store it in the respective fields. I would then use EpiDataView Notification Event in the Part form NotifyType.Initialize to View the data on the Part form. Let me know if this makes sense.
Drew
Drew
--- In vantage@yahoogroups.com, "bjcracosta" <racosta@...> wrote:
> Goal: Populate Part.ShortChar02, Part.ShortChar03, Part.ShortChar07,
> Part.ShortChar08 and Part.ShortChar09 with UD10.Key1, UD10.Character01,
> UD10.ShortChar01, UD10.ShortChar02 and UD10.ShortChar03. Table UD10
> contains bill-of-lading code details. And, display all the details in
> the part maintenance panel.
> While the following script works, it may not be the right or best way to
> achieve the goals.
> Thanks,
> Reggie Acosta
> '// Custom VB.NET code for PartForm
> '// Created: 10/16/2008 11:32:33 AM
> '// Change history:
> '// ID Pgmr Date Description
> '// XXXX XXX MM/DD/YY XXXXXXXXXXXXXXXXXXXXXXXXXXX...
> '// E19 RRA 2/18/09 Enable capture of BOL Code and display BOL code
> information.
> '// E19 o Hid lblEpiCustom1 and txtEpiCustom1 by adding
> -1000 to x location coordinate.
> '// E19 o Changed lblNetVolume.Text from "Unit Net
> Volume" to "Cube Dimension".
> '// E19 o Blanked eneNetVolume.EpiLabel property value.
> It was "lblNetVolume".
> '// E19 o Added GroupBox for "BOL Code Information"
> '// E19 - Added UltraCombo bound to Part.ShortChar02
> which will store BOL Code from UD10.Key1.
> '// E19 - Added TextBox's to display Part fields
> ShortChar02, ShortChar07, ShortChar08 and ShortChar09.
> '// E19 (BOL Code, Shipping Class, Pack Class and
> NMFC#, respectively).
> '// E19 o Added assemblies: Epicor.Mfg.AD.UD10
> '// E19 Epicor.Mfg.IF.IUD10
> '// E19 for access to UD10Adapter.
> Imports System
> Imports System.Data
> Imports System.Diagnostics
> Imports System.Windows.Forms
> Imports System.ComponentModel
> Imports Microsoft.VisualBasic
> Imports Epicor.Mfg.UI
> Imports Epicor.Mfg.UI.FrameWork
> Imports Epicor.Mfg.UI.ExtendedProps
> Imports Epicor.Mfg.UI.FormFunctions
> Imports Epicor.Mfg.UI.Customization
> Imports Epicor.Mfg.UI.Adapters
> Imports Epicor.Mfg.UI.Searches
> Imports Epicor.Mfg.BO
> Module Script
> '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard
> Added Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> '// End Wizard Added Module Level Variables **
> '// Add Custom Module Level Variables Here **
> Sub InitializeCustomCode()
> '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard
> Added Variable Intialization' lines **
> '// Begin Wizard Added Variable Intialization
> '// End Wizard Added Variable Intialization
> '// Begin Custom Method Calls
> '// <E19>
> SetExtendedProps()
> '// </E19>
> '// End Custom Method Calls
> End Sub
> '// <E19>
> Private Sub SetExtendedProps()
> '// Customization to set extended properties
> Dim edvPart As EpiDataView = CType(oTrans.EpiDataViews("Part"),
> EpiDataView)
> Dim txtBolCode As EpiTextBox =
> CType(csm.getNativeControlReference("0baaaee2-368a-4b18-966c-a0a92f98b42\
> 7"), EpiTextBox)
> If edvPart.dataView.Table.Columns.Contains("ShortChar02") Then
> txtBolCode.ReadOnly = True
> txtBolCode.Enabled = False
> End if
> If edvPart.dataView.Table.Columns.Contains("ShortChar07") Then
> edvPart.dataView.Table.Columns("ShortChar07").ExtendedProperties("ReadOn\
> ly") = True
> '//edvPart.dataView.Table.Columns("ShortChar07").ExtendedProperties("Ena\
> bled") = False
> End if
> If edvPart.dataView.Table.Columns.Contains("ShortChar08") Then
> edvPart.dataView.Table.Columns("ShortChar08").ExtendedProperties("ReadOn\
> ly") = True
> '//edvPart.dataView.Table.Columns("ShortChar08").ExtendedProperties("Ena\
> bled") = False
> End if
> If edvPart.dataView.Table.Columns.Contains("ShortChar09") Then
> edvPart.dataView.Table.Columns("ShortChar09").ExtendedProperties("ReadOn\
> ly") = True
> '//edvPart.dataView.Table.Columns("ShortChar09").ExtendedProperties("Ena\
> bled") = False
> End if
> End Sub
> '// </E19>
> Sub DestroyCustomCode()
> Added Object Disposal' lines **
> '// Begin Wizard Added Object Disposal
> '// End Wizard Added Object Disposal
> '// Begin Custom Code Disposal
> '// End Custom Code Disposal
> End Sub
> Private Sub Part_AfterFieldChange(ByVal sender As object, ByVal args
> As DataColumnChangeEventArgs) Handles Part_Column.ColumnChanged
> '// ** Argument Properties and Uses **
> '// args.Row("[FieldName]")
> '// args.Column, args.ProposedValue, args.Row
> 'Add Event Handler Code
> Select Case args.Column.ColumnName
> Case "ShortChar02"
> '// <E19> Capture BOL Code information into Part table
> CType(oTrans.EpiDataViews("Part"), EpiDataView)
> Dim UD10adapter As UD10Adapter = New
> UD10Adapter(PartForm)
> UD10adapter.BOConnect()
> Dim blnUD10 As Boolean =
> UD10adapter.GetByID(args.ProposedValue, "", "", "", "")
> Dim strBolDescr As String
> Dim strShipClass As String
> Dim strPackClass As String
> Dim strNmfcNbr As String
> If blnUD10 = True Then
> '// Copy BOL description, shipping class, pack class
> and NMFC#
> strBolDescr =
> UD10adapter.UD10Data.UD10.Rows(0)("Character01")
> strShipClass =
> UD10adapter.UD10Data.UD10.Rows(0)("ShortChar01")
> strPackClass =
> UD10adapter.UD10Data.UD10.Rows(0)("ShortChar02")
> strNmfcNbr =
> UD10adapter.UD10Data.UD10.Rows(0)("ShortChar03")
> Else
> strBolDescr = ""
> strShipClass = ""
> strPackClass = ""
> strNmfcNbr = ""
> End If
> '// Copy BOL description, shipping class, pack class and
> NMFC# into Part table
> edvPart.dataView(0)("ShortChar03") = strBolDescr
> edvPart.dataView(0)("ShortChar07") = strShipClass
> edvPart.dataView(0)("ShortChar08") = strPackClass
> edvPart.dataView(0)("ShortChar09") = strNmfcNbr
> edvPart.Notify(New EpiNotifyArgs(PartForm, edvPart.Row,
> edvPart.Column))
> UD10adapter.Dispose()
> '// </E19>
> Case Else
> End Select
> End Sub
> End Module
