Jose, are you sure its your client and not the server. Even if the CPU is not being hit that hard if your memory is maxed out or you are paging that could be the problem. If you are running SQL database you should change your progress database to read only. Also, try turning off all other databases and app servers running on the main server and see if that helps. Also, if you have not set your app servers to the proper maximum it could be that your app servers are maxed out as well.
--- On Fri, 12/19/08, Jose Gomez <jose@...> wrote:
Subject: [Vantage] Vantage Running Really SLOW Please help
Date: Friday, December 19, 2008, 4:00 PM
Hello All,
Vantage runs really slugish on all my clients. The server load is barely 20%
but all my clients run like crap.
It's Vatnage 8.03 with Progress DB
Does anyone experience this same problem and or have suggestions on how to
correct this?
Thank you
Sincerely
Jose C Gomez
http://www.josecgom ez.com
