Vantage - Quote > Order BAQ
There is also a field on the quotehed called 'ordered'. This gets ticked
whenever any of the lines from the quote are ordered.
On Mon, Feb 21, 2011 at 7:59 AM, nustepvantage <dpfiester@...> wrote:
> In Vantage 406A, when an order is created from a quote both the quote
> number and the quote line are recorded in the OrderDtl table of the sales
> order. So I would link the quotenum and quoteline fields in quotedtl and
> orderdtl. I would also do an outer join in the BAQ.
> David
> --- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> > I am trying to write a BAQ/Dashboard that will show all quotes.
> > If the quote has been won, I want it to show the order number which is
> linked to
> > the quote.
> > If a customer places an order we always create the order from the quote
> so I
> > would imagine there is a field which links the two.
> > Does anyone know which field it is?
> > Thanks.
Â
If the quote has been won, I want it to show the order number which is linked to
the quote.
Â
If a customer places an order we always create the order from the quote so I
Â
Â
Thanks.
Hi Chris,
The simplest way to achieve this would be an outer join and add order detail table to quote head and establish the relationship as company-company ,quotenum-quotenum and then display order number off orderdtl.ordernum.
I havent tried it myself but am aware that order detail has a field called quotenum.
Hopefully this will work.
Regards
Aman
> Â
> the quote.
> Â
> Â
> Â
> Thanks.
In Vantage 406A, when an order is created from a quote both the quote number and the quote line are recorded in the OrderDtl table of the sales order. So I would link the quotenum and quoteline fields in quotedtl and orderdtl. I would also do an outer join in the BAQ.
David
> Â
> the quote.
> Â
> Â
> Â
> Thanks.
