--- In vantage@yahoogroups.com, "Blake Clemens" <blake.clemens@...>
wrote:
We have tried everything suggested and did create labels from
scratch. Still not fixed. Anyone else having this problem and come
up with a solution?
wrote:
>Behalf
> Scrap the Vantage label and create your own from scratch.
> Of melissa hietalathe
> Sent: Friday, September 19, 2008 2:39 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Re: Vantage Printing Issue (8.03.4XX)
> I now have both of these options set to landscape and have adjusted
> label size in both areas as well. However, the label still printsout
> in portrait when I print from Vantage. Do you have any other ideasthat
> may be of help?the
> Thanks,
> Dustin Biniek
> UMC, Inc.
> DustinB@... <mailto:DustinB%40ultramc.com>
> ----- Original Message ----
> From: Blake Clemens <blake.clemens@...
> <mailto:blake.clemens%40d-m-c.com> >
> Sent: Friday, September 19, 2008 10:43:32 AM
> Subject: RE: [Vantage] Re: Vantage Printing Issue (8.03.4XX)
> They are pretty general, I felt rather silly after the fact. Go to
> properties of your Zebra printer. General tab-printing preferencessettings.
> button-page set up... change label size here, click Ok to save
> Also.... properties of your Zebra Printer-Advanced Tab-printingdefaults
> button-page set up... change label size here as well. Now you wouldbut
> think that by changing one it would automatically change the other
> that wasn't the case for us. Let me know if this helps you out.these
> ____________ _________ _________ __
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
> Behalf
> Of melissa hietala
> Sent: Friday, September 19, 2008 11:29 AM
> To: vantage@yahoogroups .com
> Would you happen to know where the locations were that you changed
> settings?change
> Thanks,
> Dustin Biniek
> UMC, Inc.
> DusitnB@ultramc. com <mailto:DusitnB% 40ultramc. com>
> From: Blake Clemens <blake.clemens@ d-m-c.com
> <mailto:blake. clemens%40d- m-c.com> >
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> Sent: Friday, September 19, 2008 6:44:00 AM
> We had these same types of issues with our Zebra Label Printer.
> Ultimately what solved this issue for us was that there were several
> different locations in the Zebra Label properties that you had to
> the label size. Once we did that the problem went away.4"x2",
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
> Behalf
> Of Bob Morgan
> Sent: Thursday, September 18, 2008 7:59 PM
> Subject: [Vantage] Re: Vantage Printing Issue (8.03.4XX)
> Just recently pulled my hair out over this issue. My label size is
> 4" by 2". When I set the label size in the printer default at
> it prints 90 deg rotated. When I changed to 4"x3" it prints fine!com> ,
> The printer (Zebra) seems to have a mind of its own.
> Try over sizing your label setting and you may succeed.
> Bob
> --- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> "Dale Schuerman" <dale.schuerman@ ...>com>
> wrote:
> > I ran into a similar problem on 8.03.403A that you are describing.
> > I have created/modified labels many times without any issues. We
> spent
> > more time than I want to admit chasing this problem.
> > We swapped out brands/models of printers, client computers,
> downloaded
> > and installed drivers and nothing worked.
> > I have been using CR for 8 years and have never seen the developer
> > behave differently than the "Run Time".
> > Support was unable to help (3149282MPS was the call number). We
> > abandoned Crystal Reports to print this particular label.
> > I think there is something different in the "Run Time" version of
> > Crystal versus the Developer version of Crystal on form handling.
> > If you find a solution be sure to let the group know.
> > You are not alone and good luck.
> > Dale Schuerman
> > Senior Consultant
> > RAM Software Systems, Inc.
> > 1701 North Collins Suite 200
> > Richardson, Texas 75080
> > Phone: (972) 669-0763
> > Fax: (972) 669-9603
> > Web Site: www.ramsys.com <blocked::http://www.ramsys com/
> <http://www.ramsys com/> >
> > From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> [mailto:vantage@ yahoogroups .com <mailto:vantage% 40yahoogroups.com> ]
> Onprint
> Behalf
> > Of melissa hietala
> > Sent: Thursday, September 18, 2008 4:11 PM
> > Subject: [Vantage] Vantage Printing Issue (8.03.4XX)
> > I'm looking at printing the "PTranLog" label from Vantage. When I
> > to a label printer from Vantage the label prints out in a portrait
> > orientation even though the label is customized and saved to
> inlabel
> > landscape. The printer is also set to print in landscape. If I
> > the label directly from Crystal, versus the Vantage menu, the
> > prints out correctly (in landscape orientation) . Is there someWe upgraded to 405a in August and have extactly this same problem.
> kind of
> > setting/driver in Vantage that needs to be setup or that is setup
> > incorrectly? Thanks in advance for your help.
> > Thanks,
> > Dustin Biniek
> > UMC, Inc.
> > DustinB@ <mailto:DustinB% 40ultramc. com>
up with a solution?
