I�m using PC Anywhere version 8 and have had no problems, but I set mine up
a bit differently than normal. I guess that�s just me� ANYWAY� When you
start PC/Anywhere from home and you choose �remote control� and normally it
goes out and searches the network over your VPN and displays a list of
computers �waiting for connection� with the green light. You just double
click the one you want and your there. Well that didn�t work too well for
me. I ended up Adding a Remote Control Item ( it�s a selection on the
remote control screen ). After adding this it creates a new ICON on the
Remote Control Screen in PC/Anywhere. You can edit this ICON and enter the
direct TCP/IP address of the machine you want to connect to at work. After
doing this I was online and working fine.
Hope this helps
Paul L.
Sent: Monday, November 25, 2002 2:29 PM
Subject: [Vantage] Re: Vantage over VPN connection
I have a same problem,
My Home user is at Cable Connection. We are using PC anywhere.
She gets the connection but it works very slow and sometime even
hangs.
Is there any fix you ges have?
Hope this helps
Paul L.
hangs.
--- In vantage@y..., "Paul Lipham" <pml@a...> wrote:
> I have just gotten VPN working here. I haven't been able to
install Vantage
> 5.0 at home, but loaded PC Anywhere and can remote control my
computer at
> work. I have been running Vantage this way with great success.
Login times
> are about 45 seconds and after that it's pretty much normal.
> FYI
> Paul L.
> From: Keith Goode [mailto:keithg@s...]
> Sent: Wednesday, November 20, 2002 7:14 AM
> To: vantage@y...
> Subject: RE: [Vantage] Vantage over VPN connection
> Good morning Group...
> I am attempting to connect our first home user to Vantage
over VPN. I
> was able to install the client over the VPN connection but when I
try to
> connect to the database nothing happens. I get the splash screen
then
> nothing. Any clues on where to start?
> Home user is on NT4 SP6 w\cable modem connection. Server is
2000
> w\dual ISDN connection.
> Thanks in advance
> Keith Goode
> Stauble Machine & Tool Co
must have
Builder and
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> < http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=237459.2675695.4055211.2225243/D=egroupweb/S=17050071
83:HM/A=1267611/R=0/*http://ad.doubleclick.net/jump/N2524.Yahoo/B1071650;sz=
300x250;ord=1038256149715627?>
