Vantage on Remote Server
Juliet,
We run 2 remote facilities with 3-5 Vantage users each over a T-1.
Actually, the network only gets 10/24's of the line or 640K. Our phone
system uses the rest. We cache a copy of the Vantage and Progress folders
on the remote servers.
I'm guessing response time is 1/10 as fast as what it is at our main
facility. Is it wonderful - NOT .... Does it get the job done - yup.
Todd Anderson
Sent: Wednesday, May 02, 2001 12:11 PM
Subject: FW: [Vantage] Vantage on Remote Server
We have another plant that is connected with a T1. Vantage performance
is slow. I found the bellow article in my archives. I have a few
questions on the general setup. I would like to do this.
Could anyone provide more details on doing this? What do you do with
the Progress portion of the setup? Do you point back to the original
location for that.
Thanks so much!
Juliet Martin
Sent: Friday, December 01, 2000 8:58 AM
To: 'vantage@egroups.com'
Subject: RE: [Vantage] Vantage on Remote Server
We have a similar setup except with a T1. Vantage is installed on the
remote server in exactly the same way as it's installed on the "real"
Vantage server. The Vantage mapped drive letter is the same LETTER for
users at both sites but the remote user's mapped drive is the one on
their
local server. The only difference is the vantage.vtg file on the remote
server. In the "ConnectOptions " line, replace the local server's name
with the "real" Vantage server's name.
The only problem is that every time you install Vantage on a new machine
at
the remote site, you have to fix the vantage.vtg file again. You also
have
to keep the patches and/or custom programming the same on both servers.
Greg Clauser
Lakin General Corporation
gclauser@... <mailto:gclauser@...>
We are using Vantage in two facilities, about 1 mile apart. We are
networked via a 10MBT microwave.
The IPL in the remote location is from 30 - 50 seconds. After load,
response times average around
3 seconds.
I would like to install the Vantage libraries on a server in the remote
facility, in hopes of improving
performance. I looked for a document on ERAnet that pertains to this
procedure but was unable to
find anything.
If anyone has any information on how to accomplish this, I would
appreciate
hearing from you.
Epicor has checked my LG file and has given me the thumbs up on startup
parameters.
Thanks in advance.
<http://www.egroups.com/files/vantage/>
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password,
the link above will work the next time you try it.)
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=190481.1393724.2979175.2/D=egroupmail/S=1700007183:N/
A=613962/?http://www.newaydirect.com> www.newaydirect.com
<http://us.adserver.yahoo.com/l?M=190481.1393724.2979175.2/D=egroupmail/S=17
00007183:N/A=613962/rand=610224779>
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
3 seconds.
find anything.
If anyone has any information on how to accomplish this, I would appreciate
hearing from you.
parameters.
Thanks in advance.
users at both sites but the remote user's mapped drive is the one on their
The only problem is that every time you install Vantage on a new machine at
the remote site, you have to fix the vantage.vtg file again. You also have
Greg Clauser
3 seconds.
find anything.
hearing from you.
parameters.
Thanks in advance.
location for that.
Thanks so much!
Juliet Martin
their
at
have
Greg Clauser
3 seconds.
find anything.
appreciate
hearing from you.
parameters.
Thanks in advance.
My recommendation is to not waste your time. Even with a T1 your bandwidth
is 1/10th the worst local ethernet connection. Factor in line quality and
transmission time and you will never see reasonable performance in my
opinion. We tried local and remote installs, none were acceptable, you need
to use a Citrix/Terminal server solution. There are other similar options
out there but I use Citrix Metaframe with a 384 Kbs frame circuit and have
15 remote users. The performance is about 80-90% of the normal local
connection.... Just my two cents.
PS Search the archives on this subject there is a lot of info.
Sent: Wednesday, May 02, 2001 1:11 PM
location for that.
Thanks so much!
Juliet Martin
their
at
have
Greg Clauser
3 seconds.
find anything.
appreciate
hearing from you.
parameters.
Thanks in advance.
Juliet,
If you would like to call me I can talk you through this.
Todd Anderson
IS Manager
J. Rubin & Co
815-489-7052
location for that.
Thanks so much!
Juliet Martin
their
at
have
Greg Clauser
3 seconds.
find anything.
appreciate
hearing from you.
parameters.
Thanks in advance.
