Vantage menu item for PDF document
Compiling shouldn't be necessary. Vantage will compile a selected
menu item on-the-fly. Just drop the code in a text file, and give
it .w or .p extension. Place in vantage\ud directory and attach to
menu.
Lonnie
--- In vantage@y..., Ed Kulbacki <efkcon01@y...> wrote:
> What Progress tools/utilities would I use to both
> create and then compile the program?
> Where would I locate them on my system (which
> sub-directory)and start them up?
> Ed
> --- beury@h... wrote:
> > I have several external programs running from the
> > Vantage Main Menu.
> > It makes things much easier for the end users to use
> > the Vantage
> > Menu. You guys are on the right track except that
> > you need to create
> > a small compiled Progress program to call on the
> > external program
> > from Vantage. The Progress code that I use is:
> > /* UDCR0001.p */
> > /* Call to Customer Sales Analysis Report */
> > dos SILENT
> > W:\VANTAGE\USERFORM\Crystal\custsa\custsa.exe
> > This is a Progress program to call a compiled
> > Crystal report but it
> > can be modified to call any dos/windows program.
> > Once this code is
> > compiled you can place it on the Vantage menu by
> > using "Menu
> > Structure Maintenance". It is the compiled Progress
> > program that
> > will call the external dos/windows program using the
> > syntax "ud/udcr0001.w" (without the quotes). Notice
> > that I have used
> > udcr0001 for the program name. If you don't use
> > this naming
> > convention then sometimes Vantage will choose the
> > wrong icon for the
> > menu item (I found this out the hard way).
> > P.S. I told the moderators about a year ago that I
> > would never post
> > to this list again. They were very critical of my
> > opinion of the
> > Vantage 5.0 release and scolded me like a child. My
> > Vantage
> > representative Chad Wydella also asked me not to say
> > anything bad
> > about Vantage in this newsgroup. I would like to
> > take this
> > opportunity to say that sometimes the truth hurts
> > and that this is
> > still a free country. If anyone else has similar
> > problems with big
> > brother please post it to this newgroup so that we
> > are all aware of
> > it.
> > -----Original Message-----
> > Message: 19
> > Date: Fri, 17 Aug 2001 16:55:06 -0500
> > From: Todd Caughey <caugheyt@h...>
> > Subject: RE: Re: Vantage menu item for PDF document
> > Thanks for all the discussion on this. When you
> > folks get it down to
> > something simple enough for the average person I'd
> > love to try it. I
> > had no
> > idea it was not something really commonly done.
> > Thanks again for the
> > efforts.
> > -Todd C.
> > From: Mark Charamut
> > [mailto:mrprogress@C...]
> > Sent: Friday, August 17, 2001 4:30 PM
> > To: vantage@y...
> > Subject: RE: [Vantage] Re: Vantage menu item for PDF
> > document
> > Lonnie,
> > You probably have to run adobe from a call to
> > ShellExecuteA in
> > the
> > WinAPI. Many programs that only run within windows
> > will not function
> > with an
> > os-command call. Ideally, you would query the
> > registry to find the
> > actual
> > program associated with the extension and than pass
> > the program
> > location and
> > any command line switches to ShellExecuteA.
> > Mark Charamut
> > President
> > Caesar Development Services, LLC
> > Epicor Authorized Independent Solution Provider
> > mcharamut@c...
> > www.caesardev.com
> > (860) 667-3540
> > > From: Lonnie Drew [mailto:lonniedrew@c...]
> > > Sent: Friday, August 17, 2001 5:27 PM
> > > To: vantage@y...
> > > Subject: [Vantage] Re: Vantage menu item for PDF
> > document
> > > This is weird.. I tried all below, including
> > using NO-WAIT
> > > parameter not SILENT, no luck. What are we
> > missing?
> > > --- In vantage@y..., Thad Jacobs <tjacobs@k...>
> > wrote:
> > > > this might work:
> > > > os-command silent value("acrord32.exe
> > > v:\TheDirectory\ThePDFFileName.pdf").
> > > > if not, then you may have to go with
> > > > os-command silent value("C:\Program
> > Files\Adobe\Acrobat
> > > > 4.0\Reader\AcroRd32.exe
> > > > but all users using the program would have to
> > have Acrobat reader
> > > installed
> > > > in c:\program files\
> __________________________________________________
> Do You Yahoo!?
> Make international calls for as low as $.04/minute with Yahoo!
Messenger
> http://phonecard.yahoo.com/
I would like to create a menu link to a PDF procedures manual. Is there any
way to do this? I would rather not have to create a "favorites" item on
every PC. Also, this needs to be accessable from Data Collection PCs so is
there a special security group or setting that needs to be used?
-Todd Caughey
Harvey Vogel Mfg. Co.
Here's one idea.. create a text file called say udPDF.w with command
line..
os-command silent value("v:\TheDirectory\ThePDFFileName.pdf").
Add to menu - should work.
Lonnie
there any
item on
PCs so is
> Thanks,
> -Todd Caughey
Just tried it myself --- didn't work. If I come up with the correct
command I'll post it...
Lonnie
command
> line..
> Lonnie
Is
> there any
> item on
> PCs so is
> > Thanks,
> > -Todd Caughey
this might work:
os-command silent value("acrord32.exe v:\TheDirectory\ThePDFFileName.pdf").
os-command silent value("C:\Program Files\Adobe\Acrobat
4.0\Reader\AcroRd32.exe v:\TheDirectory\ThePDFFileName.pdf").
but all users using the program would have to have Acrobat reader installed
Sent: Friday, August 17, 2001 3:31 PM
Subject: [Vantage] Re: Vantage menu item for PDF document
Lonnie
command
> line..
> Lonnie
Is
> there any
> item on
> PCs so is
> > Thanks,
> > -Todd Caughey
This is weird.. I tried all below, including using NO-WAIT
parameter not SILENT, no luck. What are we missing?
--- In vantage@y..., Thad Jacobs <tjacobs@k...> wrote:
> this might work:
installed
Lonnie,
You probably have to run adobe from a call to ShellExecuteA in the
WinAPI. Many programs that only run within windows will not function with an
os-command call. Ideally, you would query the registry to find the actual
program associated with the extension and than pass the program location and
Mark Charamut
President
mcharamut@...
www.caesardev.com
(860) 667-3540
> From: Lonnie Drew [mailto:lonniedrew@...]
> > this might work:
> installed
> ------------------------ Yahoo! Groups Sponsor
> Secure all your Web servers now: Get your FREE Guide and
> learn to: DEPLOY THE LATEST ENCRYPTION,
> DELIVER TRANSPARENT PROTECTION, and More!
> http://us.click.yahoo.com/VihfLB/nT7CAA/yigFAA/PhFolB/TM
> You must have already linked your email address to a yahoo id
> to enable access. )
> Builder and Crystal Reports and other 'goodies', please goto:
Thanks for all the discussion on this. When you folks get it down to
something simple enough for the average person I'd love to try it. I had no
idea it was not something really commonly done. Thanks again for the
efforts.
-Todd C.
Subject: RE: [Vantage] Re: Vantage menu item for PDF document
Lonnie,
Mark Charamut
President
mcharamut@...
www.caesardev.com
(860) 667-3540
> > this might work:
> installed
<http://us.click.yahoo.com/VihfLB/nT7CAA/yigFAA/PhFolB/TM>
> to enable access. )
<http://docs.yahoo.com/info/terms/>
<http://rd.yahoo.com/M=210949.1523302.3121208.1269402/D=egroupweb/S=17050071
83:HM/A=763786/R=0/*http://altfarm.mediaplex.com/ad/ck/1177-4458-1039-1?mpt=
998084153>
<http://us.adserver.yahoo.com/l?M=210949.1523302.3121208.1269402/D=egroupmai
l/S=1705007183:HM/A=763786/rand=942978095>
I have several external programs running from the Vantage Main Menu.
It makes things much easier for the end users to use the Vantage
Menu. You guys are on the right track except that you need to create
a small compiled Progress program to call on the external program
/* UDCR0001.p */
dos SILENT W:\VANTAGE\USERFORM\Crystal\custsa\custsa.exe
This is a Progress program to call a compiled Crystal report but it
can be modified to call any dos/windows program. Once this code is
compiled you can place it on the Vantage menu by using "Menu
Structure Maintenance". It is the compiled Progress program that
syntax "ud/udcr0001.w" (without the quotes). Notice that I have used
udcr0001 for the program name. If you don't use this naming
convention then sometimes Vantage will choose the wrong icon for the
P.S. I told the moderators about a year ago that I would never post
to this list again. They were very critical of my opinion of the
Vantage 5.0 release and scolded me like a child. My Vantage
representative Chad Wydella also asked me not to say anything bad
about Vantage in this newsgroup. I would like to take this
opportunity to say that sometimes the truth hurts and that this is
still a free country. If anyone else has similar problems with big
brother please post it to this newgroup so that we are all aware of
it.
Message: 19
had no
efforts.
-Todd C.
Lonnie,
the
with an
actual
location and
Mark Charamut
President
mcharamut@...
www.caesardev.com
(860) 667-3540
> > this might work:
> installed
Ed
> Vantage Main Menu.
> the Vantage
> you need to create
> external program
> /* UDCR0001.p */
> dos SILENT
> Once this code is
> using "Menu
> program that
> that I have used
> this naming
> wrong icon for the
> would never post
> opinion of the
> Vantage
> anything bad
> take this
> and that this is
> problems with big
> are all aware of
> it.
> Message: 19
> From: Todd Caughey <caugheyt@...>
> love to try it. I
> had no
> efforts.
> -Todd C.
> From: Mark Charamut
> [mailto:mrprogress@...]
> document
> Lonnie,
> ShellExecuteA in
> the
> will not function
> with an
> actual
> the program
> location and
> Mark Charamut
> President
> mcharamut@...
> www.caesardev.com
> (860) 667-3540
> document
> using NO-WAIT
> missing?
> wrote:
> > > this might work:
> Files\Adobe\Acrobat
> have Acrobat reader
> > installed
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger
