A Client install rewrites the VTG files in the Vantage directory on the
server. If they have been edited (like ours) then copy them to a safe
place and after a client install copy them back.
Just my $ 0.02
Just my $ 0.02
On 17 Jan 2001, at 10:06, Troy Funte wrote:
Each Client install DOES change things. I have to
reconfigure my Report Builder link (by deleting any
double quotes I see) whenever someone does a client
install anywhere. I could hard-code the RB shortcut
to fix the problem, but there are were other drawbacks
with that that I can't remember, so I just fix the
double-quotes once a month or so.
Troy Funte
Liberty Electronics
----- Original Message -----
To: 'vantage@egroups.com'
Sent: Wednesday, January 17, 2001 6:33 AM
Subject: RE: [Vantage] Vantage.ini file
Yes ihave the same problem. i also triedwhat you
did. no luck. Just have to
remember to add that custom reference to the ini
file every time you install
a client.
Sent: Wednesday, January 17, 2001 7:33 AM
Rick,
I don't know about ver 3. but in ver 4 were time I
install a new Client the
vantage.ini file needs to have the reference to the
custom directory put
back in. I tried making it read only...I can't
remember why.. but it didn't
work
Nancy
[mailto:rspriggle@...]
Sent: Wednesday, January 17, 2001 8:27 AM
To: vantage@egroups.com
Subject: [Vantage] Vantage.ini file
We are on 3.00.632 and just recently added some
custom programming. About
every other day the path to our custom directory
disappears from the propath
statement in the vantage.ini file. First I was
wondering what is changing
this file on a regular basis and second, can I make
it a read-only file
without suffering any evil consequences.
Rick
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
eGroups Sponsor
Click Here!
Russ Dover
IS Manager
Weaver Industries, Inc.
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
