Vantage - Houston
You've got some company ... Dril-Quip is in North West Houston. We
went live with Vantage 8.00.809f on October 30th.
Environment:
Windows Server 2003 64-bit
SQL 2005 64-bit (running in 2000 compatibility mode)
Manufacturing modules plus AR & AP
220 clients
20Gb database growing at 2Gb per month
All things considered, our experience has been smoother than
expected. My greatest concerns were that we would have major
performance and reliability problems under peak loads (which couldn't
be seen in a test environment).
After one month live, we've had a handful of instances where the
server had to be restarted due to SQL deadlocks but we found a
temporary workaround.
If we can be of assistance, don't hesitate to send an email.
Brad Feazell
IT Manager | Dril-Quip, Inc.
--- In vantage@yahoogroups.com, "Robinson, Nick" <nrobinson@...>
wrote:
> Is there anyone in the Houston TX.,area that uses Vantage?
Yes, I have been using Vantage for the last ten years or so in a machine
shop enviroment. My shop is currently using version 6.10540 but soon to
be upgrading (?) to V8.
How might I be of service?
Bob
We went live with Vantage 8.00.809c on Oct. 30th.
We use SQL Server 2000 instead of Progress.
Had been running financials on Vantage 6 since January 2004 and 8 since January 2006.
We are in La Marque, TX.
David J. Murphy
Information Systems Manager
A&A Machine & Fabrication, LLC
Elevating the Art of precision machining
and fabrication from concept to completion
Voice (409) 938-4274
Fax (409) 938-3925
www.aagroup.com
> Yes. Have used Vantage since 1999 and currently on Vantage 6.1.
Located at the Johnson Space Center, Houston, Tx.
