Hi Stephen,
Im new to all of this Vantage UD fields etc.
Is the below suggestion easy to do?
Could anyone talk me through it or does anyone have something similar that they have already created?
I can see the logic, but can't picture in my head how to put it all together.
Maybe also useful to have a check box so any parents can be ticked which may help with the dashboard when filtering results.
I look foreward to hearing any suggestions.
Regards,
CHRIS THOMPSON
Sent: Tuesday, 17 February, 2009 17:12:17
Subject: RE: [Vantage] Vantage - Customer Credit when linking Child/Parent
Chris,
If it is just a relationship between the customers you wish to establish and view you could always
Add a UD field to store the parent CustNum.
Customer.Number01 could be used.
Add a button to search and select this or a like property to allow you to right click search.
Then a simple BAQ / Dashboard added to a Tab in Customer Maintenance and Tracker would allow you to view this structure
Without having the defined business logic of parent / child in the equation.
Regards,
Stephen
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Chris Thompson
Sent: 17 February 2009 16:41
To: vantage@yahoogroups .com
Subject: [Vantage] Vantage - Customer Credit when linking Child/Parent
Hi,
We have an issue with credit limits.
We have set some of our companies up so there are parents and children.
eg Parent Company A
has 50 children who are all customers
Child Company 1
Child Company 2 etc.
At present on our old system, we can set individual credit limits per child company and they are not controlled by the parent company.
On Vantage, regardless of whether you set a credit limit for the Child company, it will always use the Parent's credit limit.
If we use the above example, where we have 50 Child companies, all with a credit limit of £3000 on our existing system, in theory if we give the Parent company £150,000 credit it should work.
However, this doesn't work for us because that means one branch (Child) could spend £140,000 leaving only £10,000 to be shared between the other 49 Children.
This leads us on to the next problem - If, on our existing system, a Child does over their individual credit limit, we can put them on stop until they pay their money, without affecting the other Children or the Parent.
However, on Vantage if we put the Child on credit hold I believe it puts the all Children and Parent on credit hold which means that none of them can buy again until they have paid some money.
Cutting a long story short, we are looking at a way to link the Parents/Children, only so that we can look on each account and see the relationship between Parent/Child if they exist.
We do not want to to have dependant Children so they all share the same credit limit.
Each child should have their own credit limit and should be put on stop when they reach the limit - this should have no affect on the other children or parent. The only link that we need to see between a Parent and Child is literally to be able to see that a Child belongs (is owned by) a Parent.
Does anybody have any work-a-rounds or solutions that they would be willing to share?
Thanks in advance.
Chris Thompson
Regards,
CHRIS THOMPSON
Chris,
Regards,
Stephen
Hi,
eg Parent Company A
Child Company 1
Thanks in advance.
Chris Thompson
