I would be careful about the decision not to use a Citrix server. It is
more expensive, but there are other uses for it that may justify the cost.
For example, you may have people who could work from home, not just in
Vantage, but with any other programs you use (Office, email, etc.). Also,
if you have people who travel occasionally, they would really benefit from
having this kind of access. The real cost savings is when you start using
it internally. We use citrix connections on our shop floor. If you buy
terminals instead of workstations for people who only use Vantage, you can
save a lot of money on hardware and hardware support. And, you can lock
them into just Vantage (or any other program you wish).
Sent: Monday, July 17, 2000 1:45 PM
To: Vantage User Group (E-mail)
Subject: [Vantage] Vantage connection via modem
We have recently hired two outside salespeople and need them to have access
to our Vantage database. We have been able to set them up where they can
access Vantage via a modem, but it is painfully slow (15 minutes just to log
in). Vantage support suggested a Citrix server. This option is expensive
considering we have only a few users that need to access Vantage in this
manner. Has anyone else had the same problem and found a less expensive
alternative?
Randall Lunsford
Excel Machinery, Ltd.
e-mail: rlunsf@...
Phone: (806) 335-4565 ext. 531
Fax: (806) 335-9017
Still looking for the complete Application Server solution?
Find answers and a $75 gift certificate at the Intraware App Server
Webinar. Sign up at:
http://click.egroups.com/1/6756/13/_/411782/_/963862923/
alternative?
Randall Lunsford
e-mail: rlunsf@...
Fax: (806) 335-9017
