I noticed that, I was doing my usual catch up here this morning and
finally ran into it. Thanks for sharing Chris.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Chris Thompson
Sent: Thursday, April 16, 2009 8:16 AM
Subject: Re: [Vantage] Re: Vantage - BAQs and Dashboards
Hi Rob,
You should see the instructions how to do it further down the list
(about 4 posts away).
Hope it works for you too.
Cheers,
CHRIS THOMPSON
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> >
Sent: Thursday, 16 April, 2009 14:05:37
Subject: RE: [Vantage] Re: Vantage - BAQs and Dashboards
Im curious myself..
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg com/>
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of Chris Thompson
Sent: Thursday, April 16, 2009 3:09 AM
To: vantage@yahoogroups .com
Hi Lynn,
I have got the Refresh and Clear buttons working very well on my
dashboard.
They are very useful and a lot faster to locate & click on than the
standard vantage ones.
Does anybody want me to post the code to add them? It's really easy in
the end after a lot of trial and error.
Cheers,
CHRIS THOMPSON
<mailto:chriselectr ix%40ymail. com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Sent: Wednesday, 8 April, 2009 8:32:31
Hi Robert,
Although the sounds tehcnically easy, its not for me (novice).
Do you have any suggestions where to start? I dont even know where the
button wizard or the tracing option is.
Also Im now having this problem where the Dashboard isn't pulling in any
information at all, even though the BAQ that drives the dashboard is
working fine.
Does anyone have any suggestions as to why it may not be pulling in any
data?
Cheers,
CHRIS THOMPSON
Sent: Tuesday, 7 April, 2009 20:15:09
When in doubt, put tracing on and hit the buttons to see what BO methods
are called (as well as any arguments they may require for a BAQ forced
refresh).
Then add your custom button controls, use the wizard to add the basic
button press/mouse click event triggered sub and within those subs add
the BO method invoking code you just discovered by tracing.
Rob
Rob Bucek
FAX: 715-284-4084
Of Chris Thompson
Hi Rob,
Cheers,
CHRIS THOMPSON
Im curious myself..
Rob Bucek
FAX: 715-284-4084
Behalf
Of Chris Thompson
Hi Lynn,
dashboard.
Cheers,
CHRIS THOMPSON
Hi Robert,
working fine.
data?
Cheers,
CHRIS THOMPSON
refresh).
Rob
--- On Tue, 4/7/09, Lynn <lynn.khalife@ core-mfg. com> wrote:
Subject: [Vantage] Re: Vantage - BAQs and Dashboards
Date: Tuesday, April 7, 2009, 9:28 AM
Sorry Chris, I don't have any idea how to add a 2nd set of those
buttons.
Regards,
Lynn
--- In vantage@yahoogroups .com, Chris Thompson <chriselectrix@ ...>
wrote:
> Hi Lynn,
> When I say I want the refresh and clear buttons on the dashboard, I
mean that instead of the user clicking on the tiny little buttons on the
standard vantage tool bar (next to delete etc), I want to add some large
clickable buttons on the tracker part of my dashboard to perform the
same tasks.
> I am happy with how the refresh, clear and refresh all buttons work, I
just want the BIGGER so clumsy fingers won't click on the wrong button.
> I have now hit a problem where the Dashboard/Tracker isn't pulling the
correct data (well any data).
> I dont know why. It was working perfectly yesterday and without
changing anything it is not working today.
> If I click Refresh it doesnt pull in any data.
> Thanks,
> CHRIS
> From: Lynn <lynn.khalife@ ...>
> Sent: Monday, 6 April, 2009 17:15:41
> So, I guess your saying that the modified BAQ will go to the dashboard
if I try opening, resaving, & restarting it.
> On your other question:
> My tracker does exactly what I need it to do.
> I followed AnswerBook 5853ESC to put a date range filter in the
tracker and I added additional filters for PartNum and PartDesc. The
"Begins With" was very useful in filtering by PartDesc.
> I didn't feel the need to add any clear & refresh buttons.
> I saw that the Clear button is for the Tracker filtering fields, and
not for the dashboard itself. And the Refresh button refreshes my
dashboard with the desired information from the Tracker filter fields.
> If I want to refresh the entire dashboard, I hit the Clear button to
clear out the filter fields, then I press the refresh button to pull in
all data again.
> I'm OK with the fact that Clear does not really clear the dashboard.
And the Refresh button always refreshes the data in the dashboard.
> A side note: I do not make the REFRESH All button available to the
users for most of my dashboards. For some dashboards, the dataset will
be too large and if the user presses "Refresh All" in error, they will
be waiting a very long time since some people are using old computers
and they are in other buildings in other cities very far from the
server. For those people who really do want to see the entire dataset
with no filters, they simply need to press 2 buttons, CLEAR & REFRESH in
order to REFRESH ALL.
> I'm satisfied with the functionality of my Clear & Refresh buttons.
I'm on 8.03.404.
> I'm not sure what you mean when you say you need to add Clear and
Refresh buttons to the "Search part of your dashboard".
> If you like, I can send you screen shots so that you can compare your
buttons to mine.
> In addition to AnswerBook 5853ESC, AnswerBook 5135ESC may also be
applicable to your tracker. I use the Epicor AnswerBooks frequently, and
unlike the on-line help, I rarely find errors in the AnswerBooks.
> Lynn
wrote:
> > Hi Lynn,
> > Ive asked Epicor the same question.
> > I am finding that the Tracker customising screen is also not doing
things that it is supposed to do.
> > I have just looked at my Dahboard, and it looks like the modified
underlying BAQ has pulled through - maybe this is just somthing that
happens once you save the Dahsboard and close it then re-open it -
perhaps it's another Vantage "feature".
> > If anybody has a solution to the code to put a Refresh, Refresh All
and Clear button on the Tracker it'd be appreciated.
> > I have tried an Answer book but it doesn't seem to work for me.
> > Has anybody else tried an answer book and had success?
> > Cheers,
> > CHRIS
> > Sent: Monday, 6 April, 2009 15:34:51
> > Chris:
> > Did you get this one figured out? I was also waiting for an answer
to your question about re-importing a BAQ and refreshing a dashboard
with a modification to the underlying BAQ.
> > I also have a Dashboard for which I created a customized tracker
last week. Later when I wanted to enhance the BAQ, I didn't know how to
get the tracker to recognize the changes to the BAQ so I ended up doing
nothing to it.
> > In the past, I always deleted the dashboards and re-created them.
However, this one has more customization on the tracker & I'd prefer to
not have to re-create it.
> > Lynn
wrote:
> > > Hi,
> > > I hope somebody can help ...
> > > If you create a BAQ and then use it in a Dashboard and add a
Tracker view, but then go back to the BAQ and add extra fields of change
the column headers, is there any way of re-importing the BAQ into the
dahboard without having to re-create the Dashboard and Tracker View etc?
> > > Also if anyone knows how to add a CLEAR, REFRESH and REFRESH ALL
button to a Dahboard, I would appreciate any help.
> > > We are on version 8.03.406A.
> > > Any help would be appreciated.
> > > Cheers,
> > > CHRIS THOMPSON
