The majority of issues we have run into during the E9 implementation have come from those areas which changed the most, financials and serialization.
Â
The 504 Service Pack (503B is the current release) is expected to be released on June 19th, assuming it passes QA. This release will address the following highlighted issues:
Â
Journal Entry - Paste/Edit does not validate GL accounts until you go to post. Epicor is changing the validation at the time of the paste so you don't end up pasting a lot of journal entries that you would have to go back and delete one at a time
Â
Alternate Bill To invoices were displaying blank (this was resolved through a patch as well)
Â
Periodic Posting Transactions were not displaying in Journal Tracker and WIP Reconcilation reports
Â
Serialization -
Â
Receipt entry does not enforce entering serial numbers for serialized parts. This is not due to be fixed until 505 service pack in September so you have to write a BPM to address this
We are receiving a Unit of Measure error when processing serialized parts through Inspection Processing. I was given a patch to try and it made some difference (before you would get an error based on the number of parts you were trying to pass/fail now it only pops up once)
Â
The other issue is that you get a warning when you click on the serial numbers button saying the transaction quantity does not match the number of serial numbers. This seems to be a message that is just in the wrong place. Once the Serial Part screen opens and it shows you the correct number of serial numbers the message goes away. You are able to get by these errors but they are a nuisance
Â
Â
Â
Â
Â
Serialization -
Â
Â
--- On Mon, 6/8/09, gsc1161 <gcreighton@...> wrote:
Subject: [Vantage] Re: Vantage 9
Date: Monday, June 8, 2009, 11:57 AM
We use alot of serialization -- what's up in 9?
--- In vantage@yahoogroups .com, Mark Wagner <mjfw2003@.. .> wrote:
> We are implementing E9 right now. Let me ask you a couple of questions and I can help pinpoint some open items
> Â
> Will you be running multi-company
> Do you use lots or serialization?
> Do you use the QA Module?
> --- On Mon, 6/8/09, Jasper Recto <jrecto@...> wrote:
> From: Jasper Recto <jrecto@...>
> Subject: [Vantage] Vantage 9
> To: "Vantage Groups (vantage@yahoogroups .com)" <vantage@yahoogroups .com>
> Date: Monday, June 8, 2009, 7:38 AM
> We have just decided to upgrade from version 6.1 to version 9. We chose version 9 over 8 because of some features that are not available in 8.
> Does anybody know of any issues we should be aware of in version 9?
> Are there any Gotha's we should be looking for in this upgrade?
> Any suggestions would be helpful!
> Thanks,
> Jasper
