John,
Thanks for the update. We did the 805 patch last night, up to the "e"
hotfix, and found so far that things are good, but we aren't using many
of the functions you listed. We use a glorified PC as our test Vantage
system and learned a lot from it, and I was glad we waited until the E
version. We really only use Financials and Customer Service pieces.
This was the first Friday after a patch that I didn't get inundated with
"now this doesn't work....."
Steven Comeau
Manager, Corporate IT Systems
Main Tape
1 Capital Drive, Suite 101
Cranbury, NJ 08512
800-718-8273 x332
_____
Sent: Friday, January 06, 2006 10:44 AM
Subject: RE: [Vantage] Vantage 8 patches -- 8.00.805E issues -- Kanban
Receipt Issue -- SCR 26947
Kanban Receipt error is covered by SCR 26947. I have been informed that
it this SCR is expected to be addressed in 8.00.805F which is expected
"soon."
John
Of John Sykes
Sent: Friday, January 06, 2006 7:29 AM
Our experience with 8.00.805E was that Kanban Receipts got busted (i.e.
behaviour regressed -- it worked in 8.00.805D and it stopped working
after 8.00.805E was applied.)
We also noted and reported a problem with the CustomerService web
services component. We use ServiceConnect to integrate external systems
and upon application of 8.00.805E we were no longer able to insert new
customer records using the web services interface/integration via
Service Connect. Specifically, the following exception was reported:
<?xml version="1.0" encoding="utf-16" standalone="yes"?>
<msg:msg xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://Epicor.com/InternalMessage/1.1
http://scshost/schemas/epicor/ScaInternalMsg.xsd"
xmlns:msg="http://Epicor.com/InternalMessage/1.1">
<msg:req tag="CustSvc.Update">
<msg:ers>
<msg:error type="unexpected error">
<msg:number>2147220990</msg:number>
<msg:description>Unspecified error: Unknown fatal errors occured: SOAP
exception occured while calling web service:
System.Web.Services.Protocols.SoapException: Server was unable to
process request. --->
Progress.Open4GL.Exceptions.RunTime4GLStopException: 4GL STOP condition:
as/activate.p activation procedure ended with an STOP condition. (8026)
(7241)
--- End of inner exception stack trace ---</msg:description>
This had the net effect of crashing the App Server associated with the
targeted instance of our Vantage implementation. To recover the Vantage
environment, the affected App Server had to be restarted via the
Progress Explorer Tool.
In both instances, this was reported immediately to Vantage Support and
in both instances, this was regressive behaviour (i.e. it worked prior
to 8.00.805E). I do not know the current SCR numbers for these issues.
We were not live at the time (we are now...) and had to develop
temporary procedures to address these issues until such time as they are
addressed by Vantage Support/Development.
In short, we found 8.00.805E to be problematic. We had no issues with
8.00.805D. Now that we are live on the product (as of 1/1/2006,) we will
be much more circumspect about patch application and will create a
wholly separate test instance/environment (i.e. unique server, unique
Progress OpenEdge environment, etc.) For what it's worth, we're Vantage
8 on SQL. Given the nature of these errors, I would expect that it is
non-database-type specific (i.e. it probably would affect both Progress
and SQL DB environments.)
Regards,
John Sykes
Director, IT
Kaleidescape, Inc.
520 Logue Avenue
Mountain View, CA
94043-4049
mailto:john.sykes@...
http://www.kaleidescape.com
tel 650.625.6161
fax 650.625.6101
IT Hotline 650.625.6180
Of Frank Zeigafuse
Sent: Friday, January 06, 2006 6:22 AM
What big problems?
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Visit www.one.org to see how the world can be changed one person at a
time.
Of
Gerard Wadman
Sent: Friday, January 06, 2006 8:04 AM
800.805 is very bad many problems.
Of
Jack
Sent: Thursday, January 05, 2006 4:08 PM
Subject: [Vantage] Vantage 8 patches
Has anyone installed all the latest patches for Vantage 8? If so, were
there any issues? I have been working on the new install of Vantage 8
and everything was working until I installed the latest patch. Just
wondering if anyone else is having issues?!
Jack
have
and
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Steven Comeau
Main Tape
Cranbury, NJ 08512
800-718-8273 x332
_____
"soon."
John
Of John Sykes
<msg:ers>
(7241)
Regards,
John Sykes
Director, IT
Kaleidescape, Inc.
520 Logue Avenue
Mountain View, CA
94043-4049
tel 650.625.6161
fax 650.625.6101
Of Frank Zeigafuse
What big problems?
Frank Zeigafuse
General Manager
time.
Of
Gerard Wadman
Of
Jack
Jack
have
and
SPONSORED LINKS
YAHOO! GROUPS LINKS
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
