Vantage 8.3 MES Screen
This applies to ver 8 platforms.
AnswerBook #: 5213MPS Product: Vantage
Added:
Changed: 04/07/2008 Module: MES
07/06/2005 Version: 8.00.800
Details:
Summary:
CUST How do you customize the main MES Menu and set to use it instead of
default
PROBLEM:
default?
SOLUTION:
1. Right-click on the shortcut for Vantage 8.0 MES.
2. Copy and paste the copy to the desktop.
3. Rename the copy to something like MES Developer.
4. Right-Click and choose Properties.
5. In the Target area, locate where it shows -MES and change it to
-MESC.
6. Click OK to save the changes.
7. Login to MES Developer.
8. Make your customizations and choose Save as
9. Give your customization a name (i.e CustomMES)
10. Save and close MES
11. Log into a your a regular 8.0 session
12. Go to System Management >> Utilites >> Sub Process Maintenance
13. Create a new menu ID and give it a name e.g UDMES1
14. Choose the security you want to apply to this option
15. Enter a parent process like PROCESS or MAINMENU
16. Enter a unique number for the sequence like 10, 15, 20, etc.
17. Under the Program section browse to or type in
Epicor.Mfg.Menu.Mes.dll
18. Choose the Customization name you saved in steps 4/5 from the list
box
19. Save and close Sub Process Maintenance
20. Create a Process Calling using System Management >> Utilities >>
Process Calling Maintenance
21. Choose File >> New
22. Process Called Reference = Epicor.Mfg.Menu.MES
23. Menu ID = UDMES1 (Menu ID create in step 13)
24. Save and close Process Calling Maintenance
25. Add the process ID you just created in step # 13 as the value for
the MESCustomMenuID node in the
xxx.mfgsys file being referenced by your MES icon
<MESCustomMenuID value="UDMES1" /> This should be listed under the
<appSettings>
</appsettings> section. If the icon does not reference mfgsys use the
default.mfgsys found
the ...epicor/client/config directory.
26. Log into 8.0 MES again and you should now see your customization.
Note 1: When first installed you will need to change the xxx.mfgsys file
used by each MES user. You'll find
this file in the config directory of the epicor client folder e.g.
c:\epicor\mfgsys803\client\config
Note 2: In a standard implementation of Vantage the name of the file
being changed is default.mfgsys.
HOWEVER, this can change based on your installation of Vantage. For
example if you are running against a
test or pilot database the file maybe named test.mfgsys or pilot.mfgsys.
You may want to check the port
number of the appserver that MES is using agains the AppServerURL
value="AppServerDC://LAPIZ:8301"
statement in the default.mfgsys.
Note 3: Be sure to change the one in the Vantage client config directory
stored on the server. This way
when you install a new release of Vantage and the client folders are
updated the modified xxx.mfgsys is
downloaded.
Of lynn_carothers
Sent: Thursday, July 09, 2009 9:01 AM
Subject: [Vantage] Vantage 8.3 MES Screen
How do I modify what the user sees when clocking into MES?
