Vantage 8.03 System Task Agent
Call me a pot-stirrer...curious if I could do it.
Progress and now my ProcessApp server won't start.
I think will restore tonight's backup tomorrow to the Train DB.
Thanks to all.
--- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@...> wrote:
> Well that opens up a whole host of other questions then.
> SQL or Progress?
> How did you create it?
> Did you create the .pf files correctly? They are highly case sensative.
> Did you properly create all appservers? Again, highly case sensative
> Did you give it unique ports in the Progress Explorer Tool?
> Do the Appservers start correctly in the PET? Did you check their status?
> Did you make all appropriate changes to the .mfgsys file and switch on the
> icon to make sure you are logging into the correct DB?
> I have a script you can use to create a new DB for Progress if you are
> interested in it instead of trying to manually set up all the parameters in
> the PET.
> From: "mustardbuzzards" <c.edwards@...>
> To: <vantage@yahoogroups.com>
> Sent: Thursday, June 18, 2009 3:07 PM
> Subject: [Vantage] Re: Vantage 8.03 System Task Agent
> > Still not working, but thanks for the input. I do appreciate it.
> > This is a new database I created, not a restore to one of the existing
> > four (4) databases.
> > Thanks to all
> > --- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@> wrote:
> >> Questions for you...
> >> Where is it not starting? In the Progress Explorer Tool or inside
> >> Vantage?
> >> Do you have the correct ports setup in the PET?
> >> Do you have the corresponding ports setup correctly in the STA setup
> >> page?
> >> Do you have the correct paths setup on the STA setup page?
> >> Do you have a valid username setup on the STA setup page?
> >> From: "mustardbuzzards" <c.edwards@>
> >> Sent: Thursday, June 18, 2009 9:31 AM
> >> Subject: [Vantage] Vantage 8.03 System Task Agent
> >> >I can not get the System Task Agent to start.
> >> > I created a new database by restoring from the live database.
> >> > The database is running fine, but I can't produce any reports without
> >> > the
> >> > task agent started.
> >> > I have compared the parameters in the app servers between the two.
> >> > Is this correct?
> >> > Any hints or ideas on where to look?
> >> > Thanks
> >> > Clinton
> >> > Trinity Yachts
> >> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> >> > have already linked your email address to a yahoo id to enable
> >> > access. )
> >> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> >> > and
> >> > Crystal Reports and other 'goodies', please goto:
> >> > http://groups.yahoo.com/group/vantage/files/.
> >> > (2) To search through old msg's goto:
> >> > http://groups.yahoo.com/group/vantage/messages
> >> > (3) To view links to Vendors that provide Vantage services goto:
> >> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
The database is running fine, but I can't produce any reports without the task agent started.
Is this correct?
Clinton
Trinity Yachts
Where is it not starting? In the Progress Explorer Tool or inside Vantage?
Do you have the corresponding ports setup correctly in the STA setup page?
> task agent started.
> Is this correct?
> Thanks
> Clinton
> Trinity Yachts
I'm new to Vantage.
Not starting inside of Vantage. Status is blank.
Ports: match. Explain more on the question: Do you have the Correct Ports setup in the PET? Are there incorrect ports?
Paths: they are same as the Live db. Is the directory fields under STA-System Appserver?
Valid Username: tried manager and mine.
After any changes, I shut down/restart all appservers.
Thanks...Clinton
> > task agent started.
> > Is this correct?
> > Thanks
> > Clinton
> > Trinity Yachts
What about the System Agent in Vantage? Did you create/update one there?
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@...<mailto:jason@...>
Yes...the ports match, auto start is checked, used two different user id, it looks like my Live STA, except for the port numbers.
Clinton
> Jason Claggett
> MCP #3856159
> 312.533.4033 x8039
Take a look through this document that I wrote a while back, it should
explain the ports to you in order to make sure they are setup correctly.
ned
Sent: Thursday, June 18, 2009 9:52 AM
> I'm new to Vantage.
> Thanks...Clinton
>> Vantage?
>> page?
>> > the
>> > task agent started.
>> > Is this correct?
>> > Thanks
>> > Clinton
>> > Trinity Yachts
>> > access. )
>> > and
In System Agent Maintenance, on Agent ID/Detail tab
under Task AppServer - Appserver URL: make sure AppServerCD:localhost:xxxx port# is correct
and under system appserver - AppServer URL: AppserverDC://localhost:xxxx make sure that port is correct also for the database you are accessing
> Is this correct?
> Thanks
> Clinton
> Trinity Yachts
Clinton,
Make sure that the password is correct on the system agent.
I worked with a customer where we set and reset the ports but not the
username and password.
It was the password that was not correct.
BTW the ports are
Task appserver - AppServerDC://localhost:8313.
03- live
13 - train
23 - test
33 - pilot
System appserver - AppServerDC://localhost:8311
01- live
11 - train
21 - test
31 - pilot
Bruce
bruce@...
www.ERPgeek.com
mustardbuzzards
Sent: Thursday, June 18, 2009 9:45 AM
Subject: [Vantage] Re:Vantage 8.03 System Task Agent
Clinton
> Jason Claggett
> MCP #3856159
> 312.533.4033 x8039
This is a new database I created, not a restore to one of the existing four (4) databases.
Thanks to all
> > task agent started.
> > Is this correct?
> > Thanks
> > Clinton
> > Trinity Yachts
SQL or Progress?
the PET.
> four (4) databases.
> Thanks to all
>> Vantage?
>> page?
>> > the
>> > task agent started.
>> > Is this correct?
>> > Thanks
>> > Clinton
>> > Trinity Yachts
>> > access. )
>> > and
