On Fri, Oct 4, 2013 at 1:07 PM, Jose Gomez <jose@...> wrote:
Â<div> <p><div dir="ltr"><div class="ygrps-yiv-1183388293gmail_default" style="font-family:verdana, sans-serif;font-size:small;">remove the stuff from form load... there is no Args in form load that's where your error comes from.</div></div>
On Fri, Oct 4, 2013 at 12:13 PM, Linda Lowney <pridesignslinda@...> wrote:Â<div> <p></p><div dir="ltr"><div>Hi Jose,</div><div> </div><div>When I open the Memo entry screen I get an error message (see below.)  Complete customization is below error message. Once I get past the error message it works great, I get <font color="#000000" face="Times New Roman" size="3"><font face="Arial"><font color="#222222">my message popping up every time I expect it to so I guess it is stil related to there being no record when the form first loads. You said to make sure args was >= 0, but I'm not sure how I'm supposed to do that, since I'm not even sure what "args" is, lol.</font></font></font><p>
Â
ÂÂError Detail
Exception has been
thrown by the target of an invocation.Â
Â
Stack Trace
  at
System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object arguments,
SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle
typeOwner)Â Â at
System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object arguments,
Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)Â Â at
System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr,
Binder binder, Object parameters, CultureInfo culture, Boolean
skipVisibilityChecks)Â Â at
Binder binder, Object parameters, CultureInfo culture)Â Â at
Epicor.Mfg.UI.Customization.CustomScriptManager.OnCustomCodeFormLoad(Object
sender, EventArgs e)Â
Inner Exception
Unable to cast object of
type 'System.EventArgs' to type 'Epicor.Mfg.UI.FrameWork.EpiNotifyArgs'.Â
Inner Stack Trace
  at Script.MemoForm_Load(Object sender,
EventArgs args)Â
ÂHere is the complete customization so far.
Â'//**************************************************
'// Custom VB.NET code for MemoForm
'// Created: 10/4/2013 11:27:11 AM
Imports System
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.FrameWorkImports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Searches
Imports Epicor.Mfg.BOModule ScriptÂÂ '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
 '// Begin Wizard Added Module Level Variables ** Private WithEvents edvMemo As EpiDataView
 '// End Wizard Added Module Level Variables **Â
 '// Add Custom Module Level Variables Here ** Sub InitializeCustomCode()
  '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
  '// Begin Wizard Added Variable Intialization
  edvMemo = CType(oTrans.EpiDataViews("Memo"), EpiDataView)
  '// End Wizard Added Variable Intialization
      Â
  '// Begin Custom Method Calls  '// End Custom Method Calls
 End Sub Sub DestroyCustomCode()
  '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
  '// Begin Wizard Added Object Disposal
  edvMemo = Nothing
  '// End Wizard Added Object Disposal
  '// Begin Custom Code Disposal  '// End Custom Code Disposal
 End Sub Private Sub MemoForm_Load(ByVal sender As object, ByVal args As EventArgs) Handles MemoForm.Load  Â       edvMemo.notify(args)
  End Sub Private Sub edvMemo_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvMemo.EpiViewNotification           messagebox.show("Notify event")    Â
   End Sub
End ModuleÂÂThanks again for all your help.ÂLindaOn Fri, Oct 4, 2013 at 10:42 AM, Jose Gomez <jose@…> wrote:
Â<div> <p></p><div dir="ltr"><div class="ygrps-yiv-1183388293gmail_default" style="font-family:verdana, sans-serif;font-size:small;">erm.. see what view those are tied to? That should work... What view are the boxes you are clicking linked to? Just remove all the IF THEN ELSE and  display a message box on notify period.</div>
On Fri, Oct 4, 2013 at 10:39 AM, Linda Lowney <pridesignslinda@...> wrote:Â<div> <p></p><div dir="ltr"><div>Hi Jose,</div><div> </div><div>Thank you for your response.  I opened memo entry and I clicked on various memos, but none of the message boxes popped up. Am I doing something wrong?</div>
ÂPrivate Sub edvMemo_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) ' Handles edvMemo.EpiViewNotification
        '// ** Argument Properties and Uses **
        '// view.dataView(args.Row)("[FieldName]")
        '// args.Row, args.Column, args.Sender, args.NotifyType
        '// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
           messagebox.show("Notify")
           Select Case args.NotifyType
               case is = EpiTransaction.NotifyType.Initialize
                   messagebox.show("Initializing")                   if (args.row >= 0) then
                       messagebox.show("row >= 0")
                   end if
               case is = EpiTransaction.NotifyType.AddRow
                If (args.Row > -1) Then                     ' don't care about this one right now
                End If
            case else
                   messagebox.show("else statement")
            End Select
    End SubÂRegards,Linda
 ÂOn Thu, Oct 3, 2013 at 4:42 PM, Jose Gomez <jose@...> wrote:
Â<div> <p></p><div dir="ltr"><div class="ygrps-yiv-1183388293gmail_default" style="font-family:verdana, sans-serif;font-size:small;">Try using the Notify -> Initialize event from the wizard. Jsut make sure that args.Row >= 0</div></div><div class="ygrps-yiv-1183388293gmail_extra">
On Thu, Oct 3, 2013 at 4:40 PM, Linda Lowney <pridesignslinda@...> wrote:Â<div> <p></p><div dir="ltr"><font color="#000000" face="Times New Roman" size="3">
Hi Group,
Â
I want to create a customization that will set some user
fields visible or invisible depending on which Memo CategoryID is displayed on
the form. I tried using the Load event but it seems that no row is
available since I received the message Index -1 is either negative or above
rows count (I could be misunderstanding the error since I don’t know much about
vb.net.) Would someone please tell me which event I should use and if I’m
using the correct one then what is wrong with the code. Â Â Also, since
the user may be moving between memos I need to know which event to use for that
as well.Â
I have it working fine when a user changes the CategoryID
(afterFieldChange), but it does not work when the memo is just displayed on the
screen.Â
Â
This is the code that does not work. Â (just trying to
display the category for now)Â
As EventArgs) Handles MemoForm.Load       '//
       '// Add Event
Handler Code       '//
      Â
        dim edv as
EpiDataView = CType(oTrans.EpiDataViews("Memo"), EpiDataView)Â
       try
          Â
dim strCategoryID as string = edv.dataView(edv.Row)("CategoryID")Â Â Â Â Â Â Â Â Â Â
messagebox.Show(strCategoryID)Â Â Â Â Â Â Â catch ex as
exception          Â
messagebox.show(ex.message)Â Â Â Â Â Â Â end
try    Â                      Â
        edv =
nothingEnd SubÂ
Â
Â
Regards,
Linda
Â
</div> <div style="color:rgb(255,255,255);"></div>
<p></p></div> <div style="color:rgb(255,255,255);"></div>
</div>
</div>
<div style="color:rgb(255,255,255);min-height:0px;"></div>
