Thanks for all the feedback. I'll give it a try!
We are using Vantage with a mulicompany structure. All companies are
running off of the same SQL database. Is there a way to a assign a
different customization to the same form in different companies? For
instance, I have a two customizations for the order entry form. I
want one of these customizations to be applied to Company A and
another to be applied to Company B. Is this possible?
It's not only possible, it's easy. When you're saving the
customisation you set it for a particular company. Internally, the
company code ends up as part of the customisation name. So use the
same customisation name when saving for each company.
Hope that makes sense.
Nigel.
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
Nigel.
wrote:
>are
> running off of the same SQL database. Is there a way to a assign aFor
Hello
Other way is to create different menu options for same screen and apply different customization and security to each option
Regards,
Jose Ferrer
To: vantage@yahoogroups.comFrom: nkerley@...: Wed, 16 May 2007 18:15:51 +0000Subject: [Vantage] Re: [Vantage 8.03] Multiple Customizations
It's not only possible, it's easy. When you're saving the customisation you set it for a particular company. Internally, the company code ends up as part of the customisation name. So use the same customisation name when saving for each company.Hope that makes sense.Nigel.--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...> wrote:>> We are using Vantage with a mulicompany structure. All companies are> running off of the same SQL database. Is there a way to a assign a> different customization to the same form in different companies? For> instance, I have a two customizations for the order entry form. I> want one of these customizations to be applied to Company A and> another to be applied to Company B. Is this possible?>
_________________________________________________________________
Discover the new Windows Vista
http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE
Regards,
Jose Ferrer
Yeah, I create seperate Menu Items for each company. So I have
Company A Job Entry and Company B Job Entry.
--SF
--SF
--- In vantage@yahoogroups.com, Jose Ferrer <ferrerj@...> wrote:
> Hello
> Regards,
> Jose Ferrer
> To: vantage@...: nkerley@...: Wed, 16 May 2007 18:15:51
<laidig.systems@> wrote:>> We are using Vantage with a mulicompany
US&form=QBRE
