Thanks Jason,
I appreciate your input.
Brian
Brian
--- In vantage@yahoogroups.com, "Jason Claggett" <jason@...> wrote:
> Brian,
> I haven't seen any responses to this yet from other users, so I'll
post
> my observations. I have several customers that use just the MES
feature
> and we see anywhere from 50MB - 89MB of memory per session (includes
> winlogin.exe, mfgsys.exe, etc...). So in your scenario you could
assume
> 1.7GB of RAM for 25 active sessions (I used 70MB as an average and
then
> X #users). If you will be just using this for terminal server then
you
> should be fine with Windows 2003 Standard R2...If you want to run
> Vantage as well, you might consider Enterprise Edition and put
Vantage
> and Terminal Server on the same server - we've seen this to be very
> effective and you don't have to deal with the loss of connectivity
issue
> that come with running terminal server and Vantage on separate
servers.
> Not knowing everything about your database or environment these are
just
> rough scenarios and not an exact science :-).
> Thanks,
> Jason Claggett
> Microsoft Small Business Specialist
> MCP #3856159
> 2W Technologies, LLC
> 317.578.2393
> jason@...
Behalf
> Of Brian Stenglein
> Sent: Monday, July 02, 2007 8:27 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Vantage 8.03 Implementation and Terminal
server
> For those of you using Terminal Sever with 8.X, can you comment on
> the server needs of data collection sessions? We are currently on
> 6.1 and have 25 data collection sessions running on a Terminal
Server
> that is pretty long in the tooth. I'm assuming we'll need a new
one,
> but I'm hoping the needs of data collections won't be as great as
> full blown users. Can anyone comment on that?
> Thanks,
> Brian Stenglein
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Gary Franks" <garyfr2003@> wrote:
> > We also are using TServer for all remote users, & I echo the
> previous
> > sentiments....about 20 users max per TServer box, so we have 3.
> > Sessions in Vantage can 'hang' if there's even the
slightest 'blip'
> in
> > connectivity, causing large scale maintenance issues for our
small
> IT
> > staff. Pretty much, we're losing lots of sleep.
> > - Gary -
> "Tim Goertz" <tim.goertz@> wrote:
> > > > Hello-
> > > > It's been awhile since I have emailed the list (being
basically
> a 2
> > > > person IT dept. and supporting about 100 + users keeps us
> pretty busy
> > > > here so I haven't had much time to keep up with the list).
> Although
> > > > still very much in the planning stages, we have decided to
> finally
> > move
> > > > from version 5.2 to V8 sometime over the next year and based
on
> the
> > > > hardware spec requirements for V8 we are aware that we will
> have to
> > > > either replace nearly every PC on our network (like I said
100
> +, 1
> > > > site) or implement V8 using terminal server as the base for
our
> > clients
> > > > access. Obviously, it seems even with the licensing
> requirements for
> > > > terminal server it would be much more economical to go that
> route
> > rather
> > > > than replacing all of our PC's and I would think would also be
> > easier to
> > > > manage and support the Vantage clients. Has anyone experienced
> > moving to
> > > > V8 with a large number of terminal server clients or
> exclusively using
> > > > terminal server? Is there any down side to running V8 via
> terminal
> > > > server vs. the full client (i.e. printing issues)? Again any
> and all
> > > > input would be appreciated. Thanks.
> > > > Tim Goertz
> > > > [Non-text portions of this message have been removed]
> > > Hi Tim,
> > > We have just started this week using 8.03 (live) and many of
our
> users
> > > are accessing via Terminal Server (2003)
> > > I would recommend against using it as each client may be using
> 150 -
> > > 300Mb memory and you will run out very fast.
> > > We have 2 TS servers, one running in VMWare, the other physical
> box -
> > > we can run 10-20 users per box before it becomes slow
> > > VM has 4 Gb physical box has 2 Gb
> > > Hope this helps
> > > Motty
