This is what I understand about Vantage standard reports:
The report invocation gives you the opportunity to select the report style that have been set up through report style maintenance.
The report produces an XML file that would be located on your Vantage server in the
\\<server name>\mfgsysdata\reports\(vantage user id)\(report type + sequential number).xml
The XML file name is passed to Crystal when the report process invokes crystal viewer.
If you are modifying a report it is best to preview a standard report first, so the XML file is produced and then can be used to test your modified report with. You can point the report you are modifying to the xml file by the Database->Set DataSource Location menu. In the bottom window area expand the create new connection and click the plus sign next to the ADO.NET (XML) icon. This will open a dialog that you use to point the report to your xml file.
(The ADO.NET datasource type is not installed by default when you install Crystal Developer)
After you have selected the xml file and it is highlighted in the bottom section, click on each ReportDataSet icon in the top section and click the update button on the right - you may have more than one ReportDataSet in the top section (if the report contains subreports) and you have to highlight and update each of them....
Always save your report as a different name or in a different folder - just in case
Happy modifying.
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of hoomail4me
Sent: Friday, August 17, 2007 2:31 PM
To:
Subject: [Vantage] Vantage 8.03 ADO.NET CR report.
I have taken the Epicor online Crystal course (VERY basic) and am scheduled for Epicor classroom training next month but cannot wait to experiment. Nothing in the online course covers standard V8 CR reports on how they are constructed (apparently they use ADO.NET).
I would like to create another report style for the RcvLabel.rpt. I can modify a copy of this report with CR Developer on my computer but when I attempt to preview I get a ADO.NET (XML) connection dialog.
Here is where I get lost. What do I need to understand regarding Vantage standard reports and the database connection.
Any direction would be greatly appreciated...
Bill
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto:
Yahoo! Groups Links
