We found another way around the partial shipment from a job bug. You can enter the job number in the box next to the order number at the top of the line detail tab in customer shipment entry. The order line and release number will disappear when you do this. You will need to re-enter the order line and release number and the job information will appear in the manufacturing box at the bottom. If this isn't the last shipment from this job you will need to uncheck the shipped complete box and save the line. Then you'll be able to change the quantity from the job. This process keeps the quantity shipped and quantity in WIP correct when you look at the job in the job tracker. If you use the Epicor workaround of deleting the link from order to job and adding it back your shipped and WIP quantities won't be right.
