If you uncheck the box for PULL AS ASSEMBLY for the component under the parent MOM, a separate job should be created to create this assembly separately.
For example, if I have a "switch assembly" that is part of the bom for the "Machine assembly" and PULL AS ASSEMBLY is unchecked for the switch assy in the machine assy MOM, a separate planning job would be done for the switch assembly when it is needed for the machine. In my case, I have the MRP planning for the switch assy part number to MRP planning quantity of 10. So, if for the machine assy 1 is needed, it will create a separate job for 10 switch assemblies, whose required date is early enough to meet the required date for the operation where the switch assembly is needed in the machine assembly.
Confusing?
Carey
To: vantage@yahoogroups.comFrom: ckrusen@...: Mon, 14 Apr 2008 20:11:18 +0000Subject: [Vantage] Re: Vantage 8.03.404 - multi level MOM's
On this topic of Multi-level MOMs....What is the difference between adding a manufactured part(that has child components) as a 'Material' vs adding it as an 'Assembly'?Will having a manufactued part as an assembly force a job to be created, even if the manufactured part is stocked and QOH is available?Calvin--- In vantage@yahoogroups.com, Carey S <rotary1@...> wrote:>> According to the documentation, this is controlled by the USE PART REVISION on the part master for that record.> If this is not selected, it will create the job or supply order based on the explicitly selected revision in the sales order.> Carey> > > To: vantage@...: manasa@...: Mon, 14 Apr 2008 08:48:21 -0500Subject: RE: [Vantage] Re: Vantage 8.03.404 - multi level MOM's> > > > > If you change a subcomponent in a MOM, it will automatically change anyMOM that uses it. At least it does in 8.00. Maybe it was a change theymade in programming?Our issue is that it uses the latest rev. I have yet to play with it ifI have multiple approved revs for the subcomponent.M. Manasa Reddymanasa@...: 630-806-2000F: 630-806-2001________________________________From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On BehalfOf c.chestSent: Monday, April 14, 2008 6:57 AMTo: vantage@...: [Vantage] Re: Vantage 8.03.404 - multi level MOM'sThe bills are pretty straight forward. For example...If part A is made up of one component...say A1, and part A is used to make part B. If I create the relationship between part B and part A in Method of Mfg and save it. Then I go back and create the relationship between part A and A1. If I look at the MOM for part B, it will not show me that part A has any components. If this doesn't happen in your system, maybe I'm doing something wrong.--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,Robert Brown <robertb_versa@> wrote:>> That is generally not true unless you use troublesome combo's of pull/view as assy and phantom/non-stock levels.> > "c.chest" <c.chest@> wrote: I have a question regarding multi-level MOM's. I am seeing that you > have to start from the ground level meaning any manufactured > components have to have their MOM completed before attaching to a > parent part. If you create the component MOM after attaching it to a > parent, it won't update the multi-level MOM of the parent part. Is > this the way Vantage works, or am I missing something. Is it really > necessary to have to un-attach a part and then re-attach it if there > is a change in the component MOM?> > > > > > > ---------------------------------> You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.> > [Non-text portions of this message have been removed]>[Non-text portions of this message have been removed] > > > > > > > __________________________________________________________> Get in touch in an instant. Get Windows Live Messenger now.> http://www.windowslive.com/messenger/overview.html?ocid=TXT_TAGLM_WL_Refresh_getintouch_042008> > [Non-text portions of this message have been removed]>
_________________________________________________________________
Confusing?
Carey
