Ok, Call the men in the white coats. I'm an idiot. Stephen you were right.
The security permissions were ok but the share permissions were not. I
opened them up and I'm able to install to the V:\prowk91d folder.
All seems ok now. I'm able to log in it seems to the default DB. Now to try
and move a copy 6.1 db from a 6.1 test pc to our 6.1 production server that
is still undergoing testing.
We are still on 4.0 for actual production.
Thanks to all for your help. I'm sure there will be more stupid questions to
come on my part.
From: Moore, Jim (Anniston) [mailto:jmoore@...-ots.com]
Sent: Wednesday, March 09, 2005 11:08 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Vantage 6.1 Installation Question
I meant Vantage.mfg file.
Sent: Wednesday, March 09, 2005 11:03 AM
I'm installing a client, the first time on this new server. Stephen the
permissions are correct, I'm a domain admin so I don't think that would be a
problem. I went with c:\epicor\MfgWk61 and it installed but I still have
problems. I don't have a mfgsys61.vtg file in my mfgsys61 folder. The
vantage shortcut is trying to find it and can't.
Sent: Wednesday, March 09, 2005 10:55 AM
Do you have the right permissions to the epicor directory?
Sent: Wednesday, March 09, 2005 10:32 AM
Subject: [Vantage] Vantage 6.1 Installation Question
I am running into problems installing the Vantage 6.1 Client.
I have installed it in the past without problems but now on a new server
I'm
having problems.
We are about to go from 4.0 to 6.1 and in 4.0 I've always installed the
Progress working directory on the server in <Network
Drive>:\Epicor\Prowork
folder.
6.1 will not allow me to install it in v:\prowk91d but says to "Please
choose a valid working directory"
The installation instructions say "24) The Shared Network Installation
Utility window appears. Enter a Working directory
(typically C:\epicor\MfgWk61 on your workstation's local drive)."
Which is correct?
I am not talking about the Local Working Directory - I know it must be at
C:\epicor\mfgwrk61.
Thanks.
Jim Moore
come on my part.
I'm
having problems.
folder.
Which is correct?
C:\epicor\mfgwrk61.
Thanks.
Jim Moore
