Dina,
We are live on 5.0 and testing 5.2 on several Vista 32 and 64 bit
machines. The only "gotcha" is the installation.
We developed the following procedure for speed, ease of use, and we were
able to script it. (install must be run as administrator - this also
assumes your .vtg files are already setup, if not, do an install on an
Windows XP client first)
1. Map network drive to Epic52 folder (we'll assume "V:").
2. Create "Prowork" folder (ProWrk52) in root of C: drive
(C:\ProWrk52).
3. Run setup.exe from the v:\progress\netsetup\ folder.
4. Run InstOCX.exe from the V:\Vantage\OCX\ folder.
5. Edit "Services" file in C:\windows\system32\drivers\etc\ (Add
line at bottom of file - "epic52 5200/tcp" make sure file ends with
a blank line!)
6. Login to pc as the normal user.
7. Copy shortcuts to client machine. (this procedure does not
auto-create shortcuts). The shortcuts must also point to the executable
first. Right click on the shortcut, select "Properties", "Target:" box
should look like this: "V:\Vantage\Vantage.exe V:\Vantage\Vantage.vtg"
without the quotes.
All done.
Jim
Of dhieber
Sent: Wednesday, July 02, 2008 1:06 PM
Subject: [Vantage] Vantage 5.2 - Vista
Good Afternoon.
Is anyone running Vantage 5.2 on a Vista machine? Where there any
"gotch's"
(i.e. Progress version, patch)
Thank you,
Dina Hieber
Vamco International, Inc.
555 Epsilon Drive, Pittsburgh, PA 15238
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
<mailto:dhieber%40vamcointernational.com>
Website; www.vamcointernational.com
This e-mail message and any files transmitted with it are confidential
and
are intended for the sole use of the intended recipient(s). Any
unauthorized
use or disclosure is prohibited. Any opinions expressed in the email are
those of the individual and not necessarily the company. If you are not
the
intended recipient, please contact the sender by reply email and destroy
all
copies of the original message.
(C:\ProWrk52).
a blank line!)
without the quotes.
All done.
Jim
Of dhieber
Good Afternoon.
"gotch's"
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
and
unauthorized
the
all
