Vantage 408B and Windows Server 2008
There is an unsupported but published registry tweak that allows Progress Explorer Tool to run on Server 2008. You set the EnableJIT flag to 0 under HKCU\Software\Microsoft\Java VM. Works for me. As suggested you can also run tool from a workstation.
Jared
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Vantage will run on Server 2008 - The progress explorer tool for setting up the db and appservers will not - you can run on a xp workstation or another 2003 server. Epicor just put out the files for a web based tool for open edge that will work with server 2008
> --- In vantage@yahoogroups.com, "Blake Clemens" <blake.clemens@> wrote:
> > Will Vantage run on Windows Server 2008?
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > Delmarva Millwork Corporation
> > (800) 360-2364 x132
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
