Vantage 4.0
Tony
If you have DMR/RMA then you will have the Quality Control
Module. The first item to deal with is every scrap pieces (non-
conforming product) from time cards goes into inspection
processing. Someone will have to decide what to do with those
(accept or reject). The RMA changes to a much more integrated
product but does require inspection processing. If I remember
correctly a GL account has to be set up for cost of scrap or
quality or something.
Warehouse bins can have a non-nettable status so that RMA, non-
conforming and receiving inspection required pieces can sit with
raising inventory value but retain their cost for transfer to a
nettable bin or a job.
We like the QC module but it took some adjusting and we don't
have it fully implemented. Mostly our fault. We were in the middle
of ISO 9002 certification with procedures in place. We didn't
want to change everything right away.
HTH
RRD
On 30 Mar 2001, at 14:18, Troy Funte wrote:
Russ,
 Are there issues with RMA/DMA between Vantage 3.0 and
4.0? If so, would you mind elaborating? We getting
close to a switch.
Troy Funte
 ----- Original Message -----
 Sent: Friday, March 30, 2001 2:13 PM
 Subject: Re: [Vantage] Vantage 4.0
 Are you aware of the changes you will have to make?
Are you
 using DMR/RMA now?
 We ran 4.0 as a test/training for a month and still
had some
 gotchas. If you have the space run them side by side.
 Just my $0.02\
 RRD
 On 30 Mar 2001, at 16:50, gtrmfg@... wrote:
 I am looking to load vantage 4.0 on and not run a
test
 for a while or
 just install everyone at once. Any suggestions??
 Russ Dover
 IS Manager
 Weaver Industries, Inc.
 717 336 7507 phone
 717 336 4182 fax
 rdover@...
 www.weaverind.com
 Yahoo! Groups Sponsor
 Click Here to Find Software Faster
 To access the Files Section of our Yahoo!Group for
Report Builder and Crystal Reports and other 'goodies',
please go to:
http://groups.yahoo.com/group/vantage/files/. Note:
You must have already linked your email address to a
yahoo id to enable access.
 Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
Russ Dover
IS Manager
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
I am looking to load vantage 4.0 on and not run a test for a while or
Are you aware of the changes you will have to make? Are you
using DMR/RMA now?
We ran 4.0 as a test/training for a month and still had some
Just my $0.02\
RRD
for a while or
Russ Dover
IS Manager
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
Russ,
Are there issues with RMA/DMA between Vantage 3.0 and 4.0? If so, would you mind elaborating? We getting close to a switch.
Troy Funte
using DMR/RMA now?
Just my $0.02\
RRD
for a while or
Russ Dover
IS Manager
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
