V8 to E9 BAQ Questions
Its under system mananagement/utilities. You create an id for your solution and when you save it automatically brings in and displays all RDD, BAQ,s Dashboards, etc., You can then decide which ones you want to maintain for that particular solution manager ID
--- On Tue, 4/27/10, Chris Thompson <chriselectrix@...> wrote:
Subject: Re: [Vantage] V8 to E9 BAQ Questions
Date: Tuesday, April 27, 2010, 4:13 AM
Â
Do you have any more information on the solutions manager?
Is it in a sub-menu?
CHRIS THOMPSON
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Tue, 27 April, 2010 2:10:29
Subject: RE: [Vantage] V8 to E9 BAQ Questions
Â
Joe, if you are just getting into E9, check out the Solutions Manager as well. They added it around 9.04 and it allows you to now transfer data definitions in additions to dashboards, BAQs, etc betwen databases. Not well publicized but finally added in E9. Look under systems management and you will see it
Date: Monday, April 26, 2010, 8:41 PM
Â
Sheesh. So simple. I just tried it and I got the same results.
I was so fixated on how it worked in V8, I just assumed it was broke. :)
Thanks Scott.
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of sysadmin@mercuryele ctronics. com
Sent: Monday, April 26, 2010 6:54 PM
We are using 9.04.506a also. Fwiw, if I open BAQ Designer, enter an
unrecognized value into the Query ID field and press tab, the app
immediately prefixes our company ID on the value and displays a "Record
not
found. Add new?" prompt.
Regards,
Scott
_____
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@ yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf Of
Mark Wagner
Sent: Monday, April 26, 2010 5:16 PM
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
I was told that too by Epicor support, but am so used to putting it in
there
that I havent tried without it. They said if you create the query ID and
description and click save it should add the company identifier in the
beginning but havent seen it work yet
<mailto:jrojas% 40matsinc. com> com> wrote:
From: Joe Rojas <jrojas@matsinc. <mailto:jrojas% 40matsinc. com> com>
Subject: [Vantage] V8 to E9 BAQ Questions
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
Date: Monday, April 26, 2010, 2:24 PM
E9.04.506A
In V8, when creating a BAQ, the Company ID would automatically populate
in the ID field and I believe that this was a requirement when creating
BAQs, the ID must be prefixed with the company ID.
When I create a BAQ in E9, the company ID does not auto populate. Does
this mean that it is not required in E9 or is it required but is a know
bug?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-1264 | fax: 781-341-5694
jrojas@matsinc. com | www.matsinc. com Ask us about our clean, green and
beautiful matting and flooring
E9.04.506A
bug?
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
I don't know if it's a bug or not but it would be recommended to include all applicable indexes in the joins. While technically it shouldn't matter in a single company setup, I have seen different query results with and without company in the joins. :shrug:
--- In vantage@yahoogroups.com, Joe Rojas <jrojas@...> wrote:
> E9.04.506A
> bug?
I was told that too by Epicor support, but am so used to putting it in there that I havent tried without it. They said if you create the query ID and description and click save it should add the company identifier in the beginning but havent seen it work yet
Â
E9.04.506A
bug?
jrojas@matsinc. com | www.matsinc. com Ask us about our clean, green and beautiful matting and flooring
immediately prefixes our company ID on the value and displays a "Record not
Regards,
Scott
_____
Mark Wagner
<mailto:jrojas%40matsinc.com> com> wrote:
From: Joe Rojas <jrojas@matsinc. <mailto:jrojas%40matsinc.com> com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
E9.04.506A
bug?
Thanks Scott.
Of sysadmin@...
not
Regards,
Scott
_____
Behalf Of
Mark Wagner
there
E9.04.506A
bug?
Â
Thanks Scott.
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
not
Regards,
Scott
_____
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf Of
Mark Wagner
there
E9.04.506A
bug?
CHRIS THOMPSON
Â
Â
Thanks Scott.
not
Regards,
Scott
_____
Behalf Of
Mark Wagner
there
E9.04.506A
bug?
I found it. This sounds pretty cool!
It is under System Management -> Utilities
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Sent: Tuesday, April 27, 2010 4:13 AM
CHRIS THOMPSON
From: Mark Wagner <mjfw2003@... <mailto:mjfw2003%40yahoo.com> >
Thanks Scott.
not
Regards,
Scott
_____
Behalf Of
Mark Wagner
there
E9.04.506A
bug?
