V8 Product Configurator
Mark
The item needs to be non- stock item and also should have approved
revision, before the configurator can be used.
Vishal
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@y...>
wrote:
> Probably will call support today, but I am playing around in the
Training
> Database trying to figure out how to implement a home-grown product
> configurator but everything related to product configuration is
grayed out. I
> see the license code in the Vantage Administrator program. Also,
no configured
> parts show up in a search although the typical suspects can be
found in the
> part screen. (CFG-PD, etc.)
> Any thoughts?
> Thanks,
> Mark W.
Probably will call support today, but I am playing around in the Training
configurator but everything related to product configuration is grayed out. I
see the license code in the Vantage Administrator program. Also, no configured
parts show up in a search although the typical suspects can be found in the
Any thoughts?
Mark W.
Mark,
This is simply because you can not access the config interface from the main
menu. You have to check out the item to an ECO and then it is available from
the action menu in the workbench.
Carey
>From: "Mark Wonsil" <mark_wonsil@...>
>Reply-To: vantage@yahoogroups.com
>To: <vantage@yahoogroups.com>
>Subject: [Vantage] V8 Product Configurator
>Date: Fri, 23 Dec 2005 08:25:51 -0500
>I
>configured
>Any thoughts?
>Thanks,
>Mark W.
Thanks.
