V8 Product Configuartor Conversion
Thanks for everyone’s reply.  Turns out it is “\” characters in the Label of the Input control.  Must be looking at it as an escape character as it is being compiled in E9
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of scott.litzau@...
Sent: Monday, September 09, 2013 1:02 PM
Subject: [Vantage] V8 Product Configuartor Conversion
Converted from 8.03.409c to 9.05.702A over Labor Day weekend and I have a configurator that worked fine under 8 but I am receiving the following when trying to compile it.
The following errors were found during compile:
CS1009 - c:\Users\ScottL\AppData\Local\Temp\ti6uplte.6.cs (2457,46) - Unrecognized escape sequence
Total number of Errors: 1, Warnings 0
In my Test DB I have removed all rules against the method and slowly removing it from input fields to see if I can find the problem.
I have a ticket open with Epicor but so far they have not located the issue.  Any ideas?
Scott
Scott
I’d bet your client version isn’t matched with the server.
Sent: Monday, September 09, 2013 2:02 PM
Scott
In my experience configurator does not upgrade you have to re-do them. I've never had anything but a VERY SIMPLE one upgrade cleanly.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
     Â
On Mon, Sep 9, 2013 at 2:02 PM, <scott.litzau@...> wrote:
Â
<div>
  <p>Converted from 8.03.409c to 9.05.702A over Labor Day weekend and I have a configurator that worked fine under 8 but I am receiving the following when trying to compile it.</p><p></p><div><br></div><div><div>The following errors were found during compile:Â </div>
CS1009 - c:\Users\ScottL\AppData\Local\Temp\ti6uplte.6.cs (2457,46) - Unrecognized escape sequenceÂ
I have a ticket open with Epicor but so far they have not located the issue. Â Any ideas?
Scott
</div>
<div style="color:#fff;min-height:0;"></div>
No, they are the same
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joe Englert
Sent: Monday, September 09, 2013 1:05 PM
Subject: RE: [Vantage] V8 Product Configuartor Conversion
Scott
We had 5 out of 9 come over fine.  I am rebuilding them, just hoping to save some time if I can find the issue.  In testing I had a mix bag of results so we were somewhat prepared for this.
Scott
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
To: Vantage
Subject: Re: [Vantage] V8 Product Configuartor Conversion
Jose C Gomez
Software Engineer
Scott
Double check to make sure you have folders under your pcrules folder that match your DB ie mine are:
\\HUMEPICOR1\Epicor905\Server\pcrules\LIVE
\\HUMEPICOR1\Epicor905\Server\pcrules\TEST
I’ve only upgraded in the 9.05 arena, but it is usually something dumb.  I have a couple pretty intense designs and haven’t had to start over yet…
Brenda
Sent: Monday, September 09, 2013 2:05 PM
To: Vantage
Jose C Gomez
Software Engineer
Scott
Brenda,
I have 5 other configurators that are working fine.  So I think the conversion process introduce some type of bad data
Scott
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of brenda mohr
Sent: Monday, September 09, 2013 1:20 PM
Brenda
To: Vantage
Jose C Gomez
Software Engineer
Scott
