We encountered the same problem. We were able to get the screens to fill-in correctly by slowing down our scanner spreed, but it would only work for a short time. We would end up adjusting the scanner speed daily. A few weeks ago I removed the tab stops on the fields we are not using on the MES screens limiting the number of tab stops that we had to build into our barcodes. Since then our problems have not resurfaced.
--- On Thu, 1/15/09, kam4085 <kmaclennan@...> wrote:
Subject: [Vantage] Re: v8 MES Barcode Problem
Date: Thursday, January 15, 2009, 1:16 PM
We are barcoding through MES. I have had to split up the job number
from the assembly.operation barcode. The form does not seems quick
enough to acknowledge the entry so we just enter using 2 barcodes
Kersten
--- In vantage@yahoogroups .com, "Ari Footlik" <ari@...> wrote:
> In trying to figure out a problem we saw with scanning our existing
(and
> working in v6) barcodes, we've been thinking we had a problem with
> system-speed. But I no longer think this is the case.
> The problem we see is that when opening the Start Production
program, we
> scan our barcode (job/tab/assy/ tab/op/tab) , but the cursor doesn't
move
> from one box to the next. However, if we keyboard-tab from the Job
to
> the Assy box, then back-tab to the Job box again, everything works
fine
> and we could scan code after code, until we close and re-open the
Start
> Production program.
> Has anyone using barcoding seen this problem and found a fix? I see
> that there are "Auto Populate" options that I think might help, but
the
> options are greyed out and cannot be selected. This is the kind of
> problem that will prevent us from going live with v8, so we're very
> hopeful that it's something simple that we're just not thinking
of...
> Thanks!
> --Ari
