1. Right-click on the shortcut for Vantage 8.0 MES.
2. Copy and paste the copy to the desktop.
3. Rename the copy to something like MES Developer.
4. Right-Click and choose Properties.
5. In the Target area, locate where it shows -MES and change it to -
MESC.
6. Click OK to save the changes.
7. Login to MES Developer.
8. Make your customizations and choose Save as
9. Give your customization a name (i.e CustomMES)
10. Save and close MES
11. Log into a your a regular 8.0 session
12. Go to System Management >> Utilites >> Sub Process Maintenance
13. Create a new menu ID and give it a name
14. Choose the security you want to apply to this option
15. Enter a parent process like PROCESS or MAINMENU
16. Enter a unique number for the sequence like 10, 15, 20, etc.
17. Under the Program section browse to or type in
Epicor.Mfg.Menu.Mes.dll
18. Choose the Customization name you saved in steps 4/5 from the
list box
19. Save and close Sub Process Maintenance
20. Add the process ID you just created in step # 8 as the value for
the MESCustomMenuID node in the xxx.mfgsys file being referenced by
your MES icon
<MESCustomMenuID value="UDMES" /> This should be listed under the
<appSettings> </appsettings> section
21. Log into 8.0 MES again and you should now see your customization.
MESC.
list box
your MES icon
--- In vantage@yahoogroups.com, "Joe Rojas" <jrojas@...> wrote:
> Hello,
> Is it possible to do customization for the MES screens?
> If so, how do you get into developer mode?
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
