Are you trying to change properties of a native control or one you've added?
(Native control property edits can be problematic at best because of their interaction with the linked business object methods.)
If you've added your own control from the toolbox, make sure you are looking at all properties (no subsections in the properties window hidden under a "+" marked summary line... indicating more detail exists if you click on the "+").
Rob
Rob
--- On Mon, 2/16/09, Karen Schoenung <kschoenung@...> wrote:
Subject: RE: [Vantage] Re: V8 Customization newbie
Date: Monday, February 16, 2009, 1:16 PM
Lynn,
Sorry, I did not put my name last time...The new issue is from me
(Karen). I don't see a "Numeric Type" control on the properties.. This
is a DockPanel (for line), MiscChrgPanel and the grdMiscChrgList - so it
only shows the fields on the far right and InvcMisc as the DataSource,
but nothing shown for DataField...
I expect since it is not a top layer field, that may be where my issue
is...
Any ideas?
Karen S
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Lynn
Sent: Monday, February 16, :40 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Re: V8 Customization newbie
Dear Kathy:
I have also found this to be very stubborn when adding user fields.
Did you double check to make sure that the "Numeric Type" on your
control matches your MaskInput? The choices for Numeric Type are
Integer & Double.
Sometimes, I have found it works if I change the Numeric Type, Save,
Exit the customization, and Exit the module. Then re-enter and
change the MaskInput and Save and Exit both the customization and the
module again before making another change.
Other than that, I have no suggestions to get around this
stubbornness of Vantage 8 customizations.
Lynn
--- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ,
"karen_schoenung" <kschoenung@ ...>
wrote:
> Hi, I have a similar situation on the Invoice Misc Charges. I have
> tried to change the mask on a custom field (Number01), but it seems
> to revert back to the original mask (I did click apply and save).
> Any suggestions?
Robert Brown <robertb_versa@ >
> wrote:
> > No problem Kathy. Consider it a Valentine's day gift! :)
> > ...Now I have to remember and race out to get my wife
> something!!! !!! ;o
> > Rob
> > --- On Fri, 2/13/09, Kathy Schaich <kathy.schaich@ > wrote:
> > From: Kathy Schaich <kathy.schaich@ >
> > Subject: RE: [Vantage] V8 Customization newbie
> > To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> > Date: Friday, February 13, 2009, 12:45 PM
> > Thank you Robert, that did the trick!
> > Kathy Schaich
> > Operations Support Manager
> > Ultra Tool & Manufacturing, Inc.
> > W169 N5954 Ridgewood Drive
> > Menomonee Falls, WI 53051
> > Phone:
> > Fax:
> > Toll Free:
> > kathy.schaich@ ultratoolmfg. com
> > www.ultratoolmfg. com
> > The information contained in this electronic message (email) and
> any
> > attachment(s) to it is/are intended for the exclusive use of the
> intended
> > addressee(s) and may contain information that is confidential
> and/or
> > privileged and exempt from disclosure under applicable law. If
you
> are not
> > the intended recipient(s) and have received this communication in
> error,
> > please do not distribute it. Instead, please notify Ultra Tool &
> > Manufacturing, Inc. at or by email at
> > general@ultratoolmf g.com and destroy all copies of this message
> and any
> > attachments. Thank you.
> > -----Original Message-----
> > From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com]
> On Behalf Of
> > Robert Brown
> > Sent: February 13, :28 AM
> > Subject: Re: [Vantage] V8 Customization newbie
> > In the properties for the control, change the mask:
> > examples:
> > nnnn (integer truncated display)
> > nnnn.nn (two decimal precision truncated display)
> > Rob
> > --- On Fri, 2/13/09, kathyschaich <kathy.schaich@
> > <mailto:kathy. schaich%40ultrat oolmfg.com> ultratoolmfg. com>
> wrote:
> > From: kathyschaich <kathy.schaich@ <mailto:kathy. schaich%
40ultrat
> oolmfg.com>
> > ultratoolmfg. com>
> > Subject: [Vantage] V8 Customization newbie
> > To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
> > Date: Friday, February 13, 2009, 9:59 AM
> > To all you Vantage 8 experts,
> > I am learning customization and am wondering if someone could
> point me
> > in the direction of how to change number formatting for the
> numeric
> > editor. I do have the Tools User Guide as a resource, just not
> real
> > sure as to what I should be looking for.
> > Thank you for any help you can give me.
> > Kathy Schaich
> > Ultra Tool & Mfg, Inc.
