V8-809 Customization Question
You got some good responses last week to this question. We put a lot of work into this.
If you change the context menu, it will get changed back with the next patch. So that is a bother.
The problem is that there might be five instances of the screen you customized, and if you don't update every one of them in the Menu Maintenance, the context menu might send users to one that was not updated. So the key is to make sure you modify every one of them. Or you can look in the context menu to see which one it sends people to, and make sure that one is updated to use the customization.
There is also a security issue here that drove us crazy for a while. We originally set up our security in as simple a way as possible. For example, we had a group called Production Control and gave them permission into the Job Management General Operations folder so they could create jobs. All the items in the Job Management General Operations folder could then be set to "Allow Access to all Groups/Users", and only Production Control could get to them. (This is a simplification). But now someone not in the Production Control group could right-click on another screen and get to Job Entry and actually make changes. What is odd is that the context menu does not always send users to the location in the menu structure that you might assume. So we had to make an extensive study of the context menu file to see where all the right-clicks led to, and then had to make sure the security was set specifically and properly at those locations. I hope that makes sense. In doing that research, we found that some of the locations in the context menu were changed from patch to patch. So caveat emptor and good luck.
Peter Volkert
Director, Information Systems
Symetrics Industries, LLC.
I can't be the only one with customized forms, so here goes.....
My customizations only seem to apply to master files when entered only from
the Vantage menu.
Created our form customizations (i.e., Part Entry) Updated via Menu
Structure to use the customization. Everything works fine when you enter
Part Entry from the Vantage menu. Then right-click (from anywhere in
Vantage) on a Part Number field to go into Part Entry, the default Part
Entry screen opens NOT my customized version.
It is a great feature in Vantage to be able to right-click and go directly
to the entry screens. The customization not only contains the form and field
layouts, but it also contains the data validation logic. The customizations
of data validation is also being bypassed. If our customizations are not
applied, it becomes more than a pointless feature.
This applies to all the customizations done thus far (Part, Sales Order, Job
Order, Customers, Suppliers, Packing Slips, AR & AP Invoicing.) You can
only access the customizations when you access the module from the menu.
Does anyone know of a way to have customizations apply to the "right-click"
entry method?
Has anyone run into this with customized trackers?
In the event this cannot be done, any suggestions other that writing
multiple BAMs to ensure data validation on update? Or is there a way to
disable the "right-click" entry option?
Thanks in advance,
Calvin
I'm still learning about customizations but the answer to your issue is
to apply the customization to the process not the menu item.
Again, I am not an expert yet...but I think you want to use 'Sub Process
Maintenance' under System Management -> Utilities
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
jrojas@...
Of Calvin Dekker
Sent: Thursday, August 31, 2006 9:34 AM
Subject: [Vantage] V8-809 Customization Question
from
the Vantage menu.
directly
field
customizations
Job
"right-click"
entry method?
Thanks in advance,
Calvin
Afternoon,
You can modify the context menu to point to your customized Part
Entry or remove the Part Entry link altogether.
Locate the ContextMenu.xml file in \epicor\oe100b\Client\res
Find the following entry and change JCMT1020 to the Menu Id of your
customized Part Entry Form.
<MenuItem>
<Name>Part Entry</Name>
<ProcessCall>JCMT1020</ProcessCall>
<ProcessType>BaseForm</ProcessType>
</MenuItem>
This file is in the client folder so each client will need to have
the updated version. To update all clients at once modify the
ContextMenu.xml in the client folder on your server then increment
the version value line in
the "\epicor\oe100b\Client\congif\default.mfgsys" file on your server
( or the configuration file your clients use ). Locate the line
<Version value="8.00.809a" /> in the <appSettings> area and change it
to something like <Version value="8.00.809a1" />. Make sure your
increment will not conflict with the next value that Epicor will use.
Wenham
issue is
Process
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
Behalf
> Of Calvin Dekker
only
> from
> the Vantage menu.
enter
Part
> directly
and
> field
> customizations
are not
Order,
> Job
can
menu.
> "right-click"
> entry method?
way to
> Thanks in advance,
> Calvin
Hello
I recomed also to go directly to the menu table in the DB (in my case we
have SQL and is easier) and apply the customizations to all part entry
options, by doing these you will be sure that all differents ways to get
that screen will have the customization
the field you need to update is "arguments" with: -c "custname"
Jose Ferrer
>From: "Wenham Burnett" <burn0051@...>
>Reply-To: vantage@yahoogroups.com
>Subject: [Vantage] Re: V8-809 Customization Question
>Date: Thu, 31 Aug 2006 18:48:47 -0000
>Afternoon,
> <MenuItem>
> </MenuItem>
>Wenham
>issue is
>Process
> > Thanks,
> > Joe Rojas
> > IT Manager
> > TNCO, Inc.
> > 781-447-6661 x7506
> > jrojas@...
>Behalf
> > Of Calvin Dekker
>only
> > from
> > the Vantage menu.
>enter
>Part
> > directly
>and
> > field
> > customizations
>are not
>Order,
> > Job
>can
>menu.
> > "right-click"
> > entry method?
>way to
> > Thanks in advance,
> > Calvin
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
we have several customizations. Job entry for one. We were able to accomplish this right click and launching the customized version by creating entries with the "Sub Process Maintenance" utility. I am not at work at the moment to give you any more details than that.
Tom Morrison
Sent: Thu 8/31/2006 9:33 AM
the Vantage menu.
entry method?
Thanks in advance,
Calvin
Just wondering if anyone is running 803 and if things seem to be
working? I noticed the downloads on the epicor website. Didn't
know where this latest release stands. The are a few updates
that we would like to take advantage of asap.
Norman Hutchins Jr.
Network Administrator
Howell Laboratories, Inc.
"Dreams are today's answers to tomorrow's questions." -- Edgar
Cayce
I am up and running this morning (test mode). I called my CAM and
requested the disks as we are going to move from 6.1 right into 803.
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of Norman Hutchins
Sent: Tuesday, September 05, 2006 1:48 PM
Subject: [Vantage] Anyonw running 803?
Norman Hutchins Jr.
Cayce
