V8.03 to E10.1 migration (pseudo-migration)
Seeing as E10 moved to the Microsoft stack, that should be enough right there. You will want per Epicor a Windows Server and E10 uses Microsoft SQL Server only. No more progress DB. Clients will also want to be within windows. I know some people have Mac work places, and even they use VM's of windows to run the software. So i'd be sure to be on the latest of microsofts stuff as that is what Epicor wants.
Were looking to switch from V8.03 to E10.1.  I say "switch" as we plan to do a virgin install of E10 and then import select data from V8.03.
Main reasons for doing this:
  • New GL structure required due to recent acquisition by another company
  • V8.03 was poorly implemented, and has too many customizations and workarounds
Our V8 install used Progress.
What are the supported O/S's (servers and Clients)?
Does E10 only use SQL?
Thanks in advance.
