V8.03 Job Tracker Customization
Oddly enough, the Labor Rate and other private information that
shows in the Labor Transactions listing can simply be Hidden in a
customization. The problem is that the private fields in the
operation list cannot. Therefore the Field Security option is
required for those.
-Peter
--- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@...>
wrote:
> I'm able to remove those fields from the list on Ver. 8.00.811B so
> maybe they took a step backward with 8.03 in this regard.
> Although, I'm not quite sure what you're trying to block.
> Labor/Burden costs are also stored in LaborDtl as well so even if
you
> have JobOper limited by field security if you will still be able to
> see the individual transactions. For example, go to the Job
Tracker
> --> Operations --> Labor Transaction, you would still get the
> labor/burden costs by employee for the selected operation. Full
> details are also available on the PDR if that's allowed as well.
> Exactly what data are you trying to limit access and why?
> --- In vantage@yahoogroups.com, "Lindquist, Pam" <plindquist@>
wrote:
> > Peter - Thanks for this info.
> > I also tried the Field Security route and that is not working
for me.
> > Will review this and try again.
> > thanks!
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
On Behalf
> > Of pvolkert365
> > Sent: Thursday, August 02, 2007 8:32 AM
> > Subject: [Vantage] Re: V8.03 Job Tracker Customization
> > We found the same problem and called it in to Support, to no
avail. I
> > guess it is a "feature", not a "bug". You can hide those fields,
but
> > when you pull up a job, they populate and show up again.
> > We fixed our problem by going to Field Security, and for the
JobOper
> > table, we only allow Accounting to see the Actual Burden and the
> > Actual Labor fields, etc. When Accounting looks at the tracker,
the
> > fields are there and populated. When anyone else looks at the
> > tracker, the fields are there, but are populated with zeroes.
> > -Peter
> > --- In vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ,
> > wrote:
> > > How do you hide the Labor, Burden, Total Cost columns on the
Job
> > Details
> > > -> Operations -> List tab?
> > > These particular columns are not listed on the customization
view for
> > > that grid. I have no trouble hiding other fields that are
listed.
> > > Appears that these costs are calculated at the time a job is
brought
> > up
> > > in Job Tracker, but there should be some way to hide them in
the list
> > > view.
How do you hide the Labor, Burden, Total Cost columns on the Job Details
These particular columns are not listed on the customization view for
that grid. I have no trouble hiding other fields that are listed.
Appears that these costs are calculated at the time a job is brought up
in Job Tracker, but there should be some way to hide them in the list
view.
We found the same problem and called it in to Support, to no avail. I
guess it is a "feature", not a "bug". You can hide those fields, but
We fixed our problem by going to Field Security, and for the JobOper
Actual Labor fields, etc. When Accounting looks at the tracker, the
-Peter
--- In vantage@yahoogroups.com, "Lindquist, Pam" <plindquist@...>
Details
up
> view.
I also tried the Field Security route and that is not working for me.
thanks!
Of pvolkert365
-Peter
Details
up
> view.
Labor/Burden costs are also stored in LaborDtl as well so even if you
see the individual transactions. For example, go to the Job Tracker
> thanks!
> Of pvolkert365
> -Peter
> Details
> up
> > view.
