Thank you for the help Dale & Rob. I ended up moving the BPM out of ARInvoice.GetById and putting it into InvcGrp.Update because ARInvoice.GetById would fire every time someone clicked on the invoice number in the group list. I had to customize the Invoice Group screen to add a checkbox that will fire the BPM.
Regards,
Linda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dale Schuerman
Sent: Wednesday, November 18, 2009 11:04 AM
Subject: RE: [Vantage] V8.03.407 BPM is causing Record has been modified by another user error.
Linda,
The "tt" fields updated the database during the "Process", so any modifications in the Post-Process must be done to the database.
The following example is saving the content of t-new-jobnum into Project.PrimaryJob.
This UpdateTableBuffer.p program is supplied by Epicor.
Run lib\updatetablebuffer.p(Input BUFFER Project:HANDLE, 'PrimaryJob', t-new-jobnum).
Hope this helps
Dale E. Schuerman
Senior Consultant
Epicor Certified Consulting Partner
RAM Software Systems, Inc.
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@... <mailto:dale.schuerman%40ramsys.com> <BLOCKED::blocked::mailto:dale.schuerman@... <mailto:dale.schuerman%40ramsys.com> > (email)
http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/> (website)
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of Linda Lowney
Sent: Wednesday, November 18, 2009 9:38 AM
Hi Rob,
The invoice number does not seem to be available during pre-processing. I added a message to display the ttInvcHead.InvoiceNum, but nothing shows up.
Linda
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf Of Rob Bucek
Sent: Wednesday, November 18, 2009 10:19 AM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Did you try this at a pre-processing?
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf Of Linda Lowney
Sent: Wednesday, November 18, 2009 8:34 AM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: [Vantage] V8.03.407 BPM is causing Record has been modified by another user error.
Hi Group,
I have this code as a Post-Processing action on ARInvoice.GetByID and it
is not allowing us to make any changes to the invoice. What I want to
happen is when an invoice is pulled into a batch I want a couple of
fields copied from order entry. What am I doing wrong?
/*Add source code that should be executed after the designed actions
here*/
for each ttInvcHead no-lock ,
each ttInvcDtl
where (ttInvcHead.Company =
ttInvcDtl.Company
and
ttInvcHead.InvoiceNum = ttInvcDtl.InvoiceNum) no-lock ,
each OrderDtl
where (ttInvcDtl.Company =
OrderDtl.Company
and ttInvcDtl.OrderNum =
OrderDtl.OrderNum
and ttInvcDtl.OrderLine
= OrderDtl.OrderLine) no-lock ,
each OrderHed
where (OrderDtl.Company =
OrderHed.Company
and OrderDtl.OrderNum =
OrderHed.OrderNum) no-lock .
if available OrderHed then do:
assign
ttInvcHead.CheckBox05 = OrderHed.CheckBox05.
end.
if available OrderDtl then do:
assign ttInvcDtl.Number01 =
OrderDtl.Number01.
end.
end.
Regards,
Linda Lowney
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Regards,
Linda
Linda,
Hope this helps
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
Hi Rob,
Linda
Rob Bucek
FAX: (715)284-4084
Hi Group,
here*/
each ttInvcDtl
ttInvcDtl.Company
and
each OrderDtl
OrderDtl.Company
OrderDtl.OrderNum
each OrderHed
OrderHed.Company
assign
end.
OrderDtl.Number01.
end.
end.
Regards,
Linda Lowney
Attention:
by MailMarshal SMTP
