We usually only route the parts to a separate rework job if we intend to
modify them into another part number. I.e. we made part X too short, but we
also make part Y which is shorter, so we can turn part X into part Y on the
rework job and receive them to stock.
For anything else, we insert a rework operation on the current job previous
to the operation it was DMR'd on--we click the "added operation" button so
we can track the additional cost, and we adjust the qty/parent for that
operation to indicate the number of parts that need to be reworked. After
rework, we then review the product on the operation it was originally
rejected on, and accept the good quantity if the rework was successful,
thereby fulfilling the demand on the original operation. If it was
unsuccessful, we repeat the process.
Amy O'Malley
Process Engineer
Heraeus Medical Components Division
(f/k/a Synovis Interventional Solutions)
8.00.811
Amy O'Malley
Process Engineer
8.00.811
On Feb 28 2008, Patrick Parker wrote:
>I have a question with regards to rework. If you have something that
>comes off a job into a DMR and you need to rework it, you can route
>the material to a new job for that rework. However, there appears no
>way to get that reworked piece back into the original job.
>We're having situations where material X is being used to produce
>part FOO. If we report a non-conformance at operation 10, we've got
>10 FOO's that we can route to a new job to rework them. But, there's
>no way to get that reworked piece back to the original job to fulfill
>the demand of operation 10. I tried to do a Make to Job link but it
>won't work because the completed FOO part is NOT a material of the
>original job - it's what is being produced.
>Seems like this should be easier to work something. Furthermore, the
>MES rework activity adds to the total number of labor quantity, so
>you can't really rework the item on the original job either and
>report quantities.
>Anyone else hit this situations and come up with a method of handling
>it. We're running 8.03.404.
