V6.0 Not able to update Customer info through Order Header Update
Heads up - we ran into a bug with updating the Customer Information like Name or Address going through the Order Header - after updating the Customer information when you return to the Order Header the information doesn't appear changed and when you click the OK button on the Order Header you get an error message "No Customer Record is available (91)".
Vantage Tech support has confirmed to be a bug and workaround is to update Customer information through the Customer Master File.
We are on 6.00.512 version.
If you would like to help get this bug fixed faster, please call Tech Support and add your company to my call # or SCR 7114 below.
Please reference call # 896464MPS if you have any additional questions on
this issue.
Your issue of No Customer Record Available (91) has been assigned Software
Change Request (SCR 7114).
Les Hanson
Aqua-Aerobic Systems, Inc.
