V408 Error Blank Title 79066
All,
Â
We found a v408 problem the hard way. It appears that the Mass Issue program requires a "To Bin" to be filled in with each line item on the BOM. This should be required ONLY for those with AMM. We do not. It has been brought to Epicor's attention and sent to the developers for resolution but if you are in your evaluation of 408 and do not use AMM, you may want to wait for the fix to become available.
Â
-Karl
