Handy little table I found.
ASCII
Code 39
ASCII
Code 39
ASCII
Code 39
ASCII
Code 39
ASCII
Code 39
A
A
a
+A
0
0
ESC (Escape)
%A
SH (Start of Heading)
$A
B
B
b
+B
1
1
FS (File Separator)
%B
SX (Start of Text)
$B
C
C
c
+C
2
2
GS (Group Separator)
%C
EX (End of Text)
$C
D
D
d
+D
3
3
RS (Record Separator)
%D
ET (End of Transmission)
$D
E
E
e
+E
4
4
US (Unit Separator)
%E
EQ (Enquiry)
$E
F
F
f
+F
5
5
%F
AK (Acknowledge)
$F
G
G
g
+G
6
6
%G
BL (Bell-Audible of Attention Signal)
$G
H
H
h
+H
7
7
%H
BS (Backspace)
$H
I
I
i
+I
8
8
HT (Horizontal Tabulation)
$I
J
J
j
+J
9
9
%J
LF (Line Feed)
$J
K
K
k
+K
/A
%K
VT (Vertical Tabulation)
$K
L
L
l
+L
/B
%L
FF (Form Feed)
$L
M
M
m
+M
/C
%M
CR (Carriage Return)
$M
N
N
n
+N
/D
%N
SO (Shift Out)
$N
O
O
o
+O
/E
_
%O
SI (Shift In)
$O
P
P
p
+P
/F
%P
DL (Data Link Escape)
$P
Q
Q
q
+Q
/G
%Q
D1 (Device Control 1-XON)
$Q
R
R
r
+R
/H
%R
D2 (Device Control 2)
$R
S
S
s
+S
/I
%S
D3 (Device Control 3-XOFF)
$S
T
T
t
+T
/J
DEL
%T
D4 (Device Control 4)
$T
U
U
u
+U
/K
NU (Null)
%U
NK (Negative Acknowledge)
$U
V
V
v
+V
/L
%V
SY (Synchronous Idle)
$V
W
W
w
+W
/M
%W
EB (End of Transmission Block)
$W
X
X
x
+X
/N
SP
(= or ~ in our fonts <http://www.idautomation.com/fonts/code39/> )
SP
CN (Cancel)
$X
Y
Y
y
+Y
/O
EM (End of Medium)
$Y
Z
Z
z
+Z
/Z
SB (Substitute)
$Z
Of Rudy Rodriguez
Sent: Thursday, September 13, 2007 11:45 AM
Subject: RE: [Vantage] V 8.03.305 ERRR....400 Bar Code Scanning in MES
Todd,
If you are using Code39 font I believe it is either $I or $M one or the
other
Behalf
Of Todd Hofert
Sent: Wednesday, August 29, 2007 6:47 AM
Subject: [Vantage] V 8.03.305 ERRR....400 Bar Code Scanning in MES
We are trying to effectively use bar code scanners in the MES Interface
to streamline data collection tasks. We are running into problems
getting the scanner to advance to the next field without having to press
the tab key. Can anyone offer advice how to get the cursor to auto
advance after scanning a barcode? I have programmed an ENTER into the
scanner and have tried the option to treat ENTER as TAB but that doesn't
work. I can't find a way to program a TAB into the scanner. Not sure how
to accomplish this. It seems there are some over sights to efficient
scanning in the interface but maybe it is just me not 'getting it'.
Todd Hofert
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
ASCII
Code 39
ASCII
Code 39
ASCII
Code 39
ASCII
Code 39
ASCII
Code 39
A
A
a
+A
0
0
ESC (Escape)
%A
$A
B
B
b
+B
1
1
FS (File Separator)
%B
SX (Start of Text)
$B
C
C
c
+C
2
2
%C
EX (End of Text)
$C
D
D
d
+D
3
3
%D
$D
E
E
e
+E
4
4
US (Unit Separator)
%E
EQ (Enquiry)
$E
F
F
f
+F
5
5
%F
AK (Acknowledge)
$F
G
G
g
+G
6
6
%G
$G
H
H
h
+H
7
7
%H
BS (Backspace)
$H
I
I
i
+I
8
8
>%I
$I
J
J
j
+J
9
9
%J
LF (Line Feed)
$J
K
K
k
+K
/A
%K
$K
L
L
l
+L
/B
%L
FF (Form Feed)
$L
M
M
m
+M
/C
%M
$M
N
N
n
+N
/D
%N
SO (Shift Out)
$N
O
O
o
+O
/E
_
%O
SI (Shift In)
$O
P
P
p
+P
/F
%P
$P
Q
Q
q
+Q
/G
%Q
$Q
R
R
r
+R
/H
%R
$R
S
S
s
+S
/I
%S
$S
T
T
t
+T
/J
DEL
%T
$T
U
U
u
+U
/K
NU (Null)
%U
$U
V
V
v
+V
/L
%V
$V
W
W
w
+W
/M
%W
$W
X
X
x
+X
/N
SP
SP
CN (Cancel)
$X
Y
Y
y
+Y
/O
EM (End of Medium)
$Y
Z
Z
z
+Z
/Z
SB (Substitute)
$Z
Of Rudy Rodriguez
Todd,
other
Behalf
Of Todd Hofert
Todd Hofert
