Hello All,
The title is paradoxical, but bear with me for a second. What I am trying to do is understand manufacturing variances that get posted to the general ledger by using the job production detail report. I am most concerned with material variances. Most of the time we are dealing with material usage variances when it comes to material variances AND material cost makes up the bulk of our cost of goods sold. The hard part is trying to make a concise report that breaks down what happened on each of the jobs that contributed to the variance and whether the variance was a usage variance or caused by something else (as mentioned below).
It is easy to see why a material usage variance exists by comparing what was required for the job v.s. what was used- as long as what is required matches the required amount that was used when the standard cost was established for the manufactured part. I understand there may be other factors like an increase in raw material/component standard costs, but generally we are rolling parent parts when subcomponent standard costs are rolled.
I would love to use the production detail report since it already breaks out estimated v.s. actual, but what I am finding is that we typically produce less than the job quantity due to our manufacturing process and the way we consume raw materials (we don’t open a brand new lot of raw materials if the quantity remaining on the job is less than X amount- we just end the job where it’s at as long as it covers the demand).
When you run the production detail report, it uses the estimates for the full job quantity, but that isn’t what we produced to. For example, our job calls for 90,000 LF of material, but we produce 87,000 LF due to the process outlined above.
87,000 is the final amount and that is what I would like the production detail report to use when it is calculating the estimated costs, but I am having trouble understanding when you need to change this quantity in order for the estimated costs to come in correctly.
In short, when do you need to change the job production quantity so that the production detail report calculates estimated costs correctly? Is it before the job is released? Before the job is started?
Am I coming at this all wrong and does some report already exist that would help point out what type of variance it was?
If I can clarify at all let me know.
On the other hand, if anyone has already written a BAQ or report to deal with this, we would be more than thankful for a copy of it!
