Using MES Labor Records for Time Studies
The job tracker screen shows estimated vs actual hours, but I haven't
found a good summary screen. The project tracker screen does summarize
all job time, if you work on projects, but not really useful for
continuous manufacturing.
We have written a few custom reports to get that info:
- monthly plant efficiency - jobs closed that month, est vs
actual time for entire job
- daily shift efficiency - est vs actual based on qty completed
that shift (not total job qty)
- direct vs indirect % & log-in % by employee
Contact me off-list if you're interested in these reports... I can share
bits of them, but not the entire report.
And we've turned on the change log on PartOpr to track the history of
production standard changes, and a screen customization that stores the
original standard we quoted at in Number01.
Brian.
Of tchristie1
Sent: Tuesday, January 31, 2012 10:50 AM
Subject: [Vantage] Using MES Labor Records for Time Studies
We went live with Epicor 9.05.606 at the beginning of the month and seem
to rolling along quite smoothly. As we move forward though I am looking
to begin using the data we are collecting on our jobs.
We are inputting the labor transactions through MES against the jobs but
I have not seen how to use this information. Ideally, I would like to be
able to do a couple things:
(1) Compare all jobs estimated labor versus actual labor so that I can
identify BOOs that are inaccurate and need updating.
(2) Perform a time study on a particular part and see how long much
labor was required to produce the parts historically.
(3) Perform a "labor roll-up" to determine the total labor required to
produce a finished good that may have multiple jobs that flowed into it.
The one I am most interested in has over 40 independent jobs to build
subcomponents as well as 5 separate major assembly jobs. It's a real
beast.
Does anyone know of built in tools to help with this? Does anyone have a
dashboard or report that I could use as a starting point? I'm sure with
enough time I can build these myself but I'd rather not reinvent the
wheel!
Tom
We went live with Epicor 9.05.606 at the beginning of the month and seem to rolling along quite smoothly. As we move forward though I am looking to begin using the data we are collecting on our jobs.
We are inputting the labor transactions through MES against the jobs but I have not seen how to use this information. Ideally, I would like to be able to do a couple things:
(1) Compare all jobs estimated labor versus actual labor so that I can identify BOOs that are inaccurate and need updating.
(2) Perform a time study on a particular part and see how long much labor was required to produce the parts historically.
(3) Perform a "labor roll-up" to determine the total labor required to produce a finished good that may have multiple jobs that flowed into it. The one I am most interested in has over 40 independent jobs to build subcomponents as well as 5 separate major assembly jobs. It's a real beast.
Does anyone know of built in tools to help with this? Does anyone have a dashboard or report that I could use as a starting point? I'm sure with enough time I can build these myself but I'd rather not reinvent the wheel!
Tom
