IS it possible to use a IIF statement in the WHERE statement? For example?
IIF(@ReportType = 1 AND @Quantity = 0, THEN Erp.PlantWhse.PrimeBin = @Bin,
ELSE IF @ReportType = 1, THEN Erp.PlantWhse.PrimeBin = @Bin AND Erp.PartBin.OnHandQty >= @Quantity,
ELSE Erp.PartBin.BinNum = @Bin AND Erp.PartBin.OnHandQty >= @Quantity)
Not to dynamically change the Where criteria (as in which criteria to use). But I think your logic needs some work. It looks like you want three distinct Where clauses:
(when @ReportType = 1 AND @Quantity = 0) -
(when @ReportType = 1 AND @Quantity <> 0) -
(when @ReportType <> 1)
So just roll your params into the individual where clauses, like
SELECT *
FROM T1
WHERE ((@ReportType = 1 AND @Quantity = 0 AND T1.PrimeBin = @Bin)
OR (@ReportType = 1 AND @Quantity <> 0 AND T1.PrimeBin = @Bin AND T1.OHQ >= @Quantity)
OR (@ReportType = <> 1 AND T1.PrimeBin = @Bin AND T1.OHQ >= @Quantity))
Are you talking about the SSRS query? If so, you can use a CASE statement, but you still need to get data first to filter. Also, your IIF statement is quite a bit off.
I find it simpler to filter the Tablix.
