Ok, I’m having some difficulty figuring out what should be simple. I know I’m just missing a step somewhere. I’ve created my external DLL and put it in the correct place. I can see it and reference it and its methods from the BPM designer.
I’ve added my using statement.
But when I go to enable it and save I get this:
There is at least one compilation error.
Update.Pre.test.cs(13,7): error CS0246: The type or namespace name ‘nonConfBPM’ could not be found (are you missing a using directive or an assembly reference?)
hmm. You might need to mess around removing the dll from the folder and re-adding it.
I recall seeing this myself but struggling to remember exactly what I did to repair.
Might need to recycle the IIS pool as well.
Thanks for the replies guys. Strangely enough it turned out the problem was the using statement itself. I removed that and everything worked perfectly.
