Never Mind - I figured it out. the run-time arg "Config" was pointing to a different configuration file. Once I edited that, it worked like it should.
--- In vantage@yahoogroups.com, "keithfwalter@..." <keithfwalter@...> wrote:
> I, also, have customized MES - programmed a button to launch the Serial Number Assignment UI. I created a Sub-process record for the customization with the following values:
> Name: MES Buttons Added
> Security ID: SEC000
> Parent Process: PROCESS
> Oder Seq: 10
> Enabled: TRUE
> Program Type: Non Menu Item
> Program: Epicor.Mfg.Menu.Mes.dll
> Customization: kfwMES01
> Then, per HELP, I modified the config file with the following in the appSettings section:
> <MESCustomMenuID value="UD-MES" />
> But when I open MES, I do not see my customization. Any idea's why not would be appreciated!
> BTW, we are not live, and I am doing this all in Pilot. Here is the target for my MES icon (Pilot DB):
> "C:\Program Files\Epicor Software\client803\client\MfgSys.exe" -MES /config=pilot.mfgsys
> Thanks,
> Keith Walter
> --- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@> wrote:
> > Jase,
> > In the default.mfgsys file there under the <appSettings> section there is a
> > setting <MESCustomMenuID value="" />. Place the ID you created in the Sub
> > process menu between the quotes and the Customized MES will come up.
> > There is a good Help section in Vantage which walks you right through the
> > entire process.
> > Scott Litzau, MCP
> > Olympus Flag & Banner
> > Information Systems Manager
> > scott.litzau@
> > P: 414-365-9732
> > F: 414-355-1931
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > precisionerp
> > Sent: Monday, November 20, 2006 3:54 PM
> > Subject: [Vantage] Using customized MES buttons V8.00.809d
> > Hi, I have just added the scheduled shipments report to a button on the
> > MES menu. I have tested it and it all works fine. The next thing i need
> > to do is to set this customization as the default for MES. Can anyone
> > tell me how to do this?
> > Thanks Jase.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Yahoo! Groups Links
