Using ARCserveIT to back up Vantage
Gary
We use ArcserveIT to back up our server. We use Progress' Backup utility to
create a backup file that goes on the tape. We used the Directory tree to
delselect those files and yes new files are skipped. Of course you can not
use the tree to deselect and put up with all the error messages. Since the
Directory is stable except for upgrades if you do the selection after each
upgrade you should catch all the files. We seem to.
Russ Dover
Weaver Industries.
On 26 Sep 00, at 12:44, Gary Schmucker wrote:
To: <Vantage@egroups.com>
Organization: Lycro Products
Date sent: Tue, 26 Sep 2000 12:44:54 -0500
Send reply to: vantage@egroups.com
Subject: [Vantage] Using ARCserveIT to back up Vantage
> Gary Schmucker
> Lycro Products Co., Inc.
> P.O. Box 571
> 66557 St. Rd. 19
> Wakarusa, IN 46573-0571
> Phone: (219) 862-4981
> Email: gslycro@...
> Hi all,
> I'm new to this IT professional thing so please bare with me!! We are using
> Vantage 4.0 and are using ARCserveIT Workgroup Edition 6.61 to back up our
> windows NT server which has the Vantage database on it. At one time we were
> going to use the addon on agent for open files to back up the vantage
> database but then epicor suggested using there backup utility in vantage.
> so, we have switched to using this utility and epicor stated that we should
> exclude the database from the ARCserve daily backup. My main question is
> this.....Computer Associates, the makers of ARCserveIT, stated in one of
> there documents that if you use the directory tree to select or deselect the
> files that you want backed up, only the files which are on the server at the
> time the backup job was created will be backed up in the future. They
> stated that they use a "snapshot" of the hard drive at the time the job was
> created and use that same snapshot for all scheduled backups that use that
> backup job and the backup job does not look for
> -Gary Schmucker
> We no longer allow attachments to files. To access/share Report Files, please
> go to the following link: http://www.egroups.com/files/vantage/ (Note: If this
> link does not work for you the first time you try it, go to www.egroups.com,
> login and be sure to save your password, choose My Groups, choose Vantage, then
> choose Files. If you save the password, the link above will work the next time
> you try it.)
Russ Dover
rustover@...
717 336 2340 voice
717 336 2646 fax
Gary Schmucker
P.O. Box 571
66557 St. Rd. 19
Email: gslycro@...
Hi all,
I'm new to this IT professional thing so please bare with me!! We are using Vantage 4.0 and are using ARCserveIT Workgroup Edition 6.61 to back up our windows NT server which has the Vantage database on it. At one time we were going to use the addon on agent for open files to back up the vantage database but then epicor suggested using there backup utility in vantage. so, we have switched to using this utility and epicor stated that we should exclude the database from the ARCserve daily backup. My main question is this.....Computer Associates, the makers of ARCserveIT, stated in one of there documents that if you use the directory tree to select or deselect the files that you want backed up, only the files which are on the server at the time the backup job was created will be backed up in the future. They stated that they use a "snapshot" of the hard drive at the time the job was created and use that same snapshot for all scheduled backups that use that backup job and the backup job does not look for new files that may have been added to the directory in which files were deselected. Is this true? If so, how can you automatically update the "snapshot"? I was told that you could use the filter option and not deselect individual files but that would take much too long to configure for all the files that we do want excluded. Any ideas or suggestions? Should we possibly go ahead and use the backup agent for open files and not deselect anything? Any help would be greatly appreciated!! Thanks for helping a newbie!!
-Gary Schmucker
Gary,
You are okay excluding the Vantage\DB directory no matter what. All the info
you need is taken care of with Vantage's backup utility.
Eric Tolliver
IT\MIS
Continental Industries Inc.
5456 E. Mcdowell Rd.
Mesa, Az 85215
http://ciirelays.com/
mailto:e.tolliver@...
Hi all,
-Gary Schmucker
I'm not new to IT, but I am new to ARCserveIT. I have been using it for the
past 3 months, and I don't really care for it compared to BackupExec.
Anyway, someone can correct me if I am wrong, but I believe the Vantage
backup simply makes a copy of the data that doesn't remain open, thereby
allowing ARCserveIT to back it up clean. The stuff that is open in Vantage
can remain in the backup job, and it will get skipped because it is open. I
am doing a full-backup of the server that contains the Vantage files.
Sent: Tuesday, September 26, 2000 11:45 AM
To: Vantage@egroups.com
Gary Schmucker
P.O. Box 571
66557 St. Rd. 19
Email: gslycro@...
Hi all,
-Gary Schmucker
Yes it will usually state that the file is in use and skip it. BackupExec
does the same thing.
Eric Tolliver
IT\MIS
Mesa, Az 85215
Sent: Tuesday, September 26, 2000 11:35 AM
To: 'vantage@egroups.com'
Subject: RE: [Vantage] Using ARCserveIT to back up Vantage
I use ARCserve Manager (the original from Chyenne Software) and it will
backup all the files on my server, open or not, except for several DHCP
related files. I don't recall installing the open file routine; maybe the
version I am running doesn't need it. Anyway, I check my logs everyday and
test the backup tapes for integrety weekly (I do a sample restore to a
folder setup for that purpose). Have had zero problems with tapes and drive
since install July 1998 - now I have probably jinked myself; oh well.
Jim Stetter
Snow Filtration
Sent: Tuesday, September 26, 2000 2:35 PM
the
Vantage
I
Gary Schmucker
P.O. Box 571
66557 St. Rd. 19
Email: gslycro@...
Hi all,
up
we
should
the
the
was
been
would
excluded.
-Gary Schmucker
to
Groups,
above
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
hello all,
thanks for your help in easing my fears of the vantage database not
being backed up in ARCserve!! now my only fear is this......how bout any
other files that are added after the initial backup job configuration? are
these definitely going to be backed up? thanks again!!!
-Gary Schmucker
----- Original Message -----
To: <vantage@egroups.com>
Sent: Tuesday, September 26, 2000 1:01 PM
> Gary,
info
> Eric Tolliver
> IT\MIS
> Mesa, Az 85215
> Hi all,
up
we
should
the
the
was
been
would
excluded.
> -Gary Schmucker
