Martin,
Do you have an example, or instructions for how this is used to have
the user input some information. Thanks.
Tim Care
Electro Chemical Finishing
Tim Care
----- Original Message -----
To: <vantage@egroups.com>
Sent: Monday, November 27, 2000 4:18 PM
Subject: RE: [Vantage] User Input to Report Builder
> Yes there is It's a calculated field: "Runtime".
> Martin Nijdam (Jr. Ing.)
> Suss Woodcraft Int'l
> (514) 363-3565
> > -----Original Message-----
> > From: Tim Care [SMTP:ecfmis@...]
> > To: vantage@egroups.com
> > Subject: [Vantage] User Input to Report Builder
> > Is there a way to have a user enter data when the
> > report runs? We have a report where we need the
> > user to enter a percentage when they run the report,
> > and this percentage may vary from part to part, so using
> > just a static value won't work. Any ideas?
> > Thanks in advance.
> > Tim Care
> > We no longer allow attachments to files. To access/share Report Files,
> > please go to the following link: http://www.egroups.com/files/vantage/
> > (Note: If this link does not work for you the first time you try it, go
> > to www.egroups.com, login and be sure to save your password, choose My
> > Groups, choose Vantage, then choose Files. If you save the password,
the
> > link above will work the next time you try it.)
Groups, choose Vantage, then choose Files. If you save the password, the
