Hey Brad, I think if you are wanting a custom dialog box, you’ll have to code one up yourself and then invoke it. It’s kind of a pain in the a$$ but definitely doable.
In the example below, I use several different custom dialog prompts and hopefully you can get the idea of how to do it.
// Custom code for MainController
// Created: 12/19/2016 4:02:57 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using System.Text;
public class Script
this.btnGetCode.Click += new System.EventHandler(this.btnGetCode_Click);
this.btnReset.Click += new System.EventHandler(this.btnReset_Click);
this.btnGetCode.Click -= new System.EventHandler(this.btnGetCode_Click);
this.btnReset.Click -= new System.EventHandler(this.btnReset_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void btnReset_Click(object sender, System.EventArgs args)
//clear fields
txtShipViaCode.Clear();
txtCarrierCode.Clear();
txtServiceCode.Clear();
txtBoxCode.Clear();
txtIceCode.Clear();
private void btnGetCode_Click(object sender, System.EventArgs args)
//local variables to build out Ship Via Code
string carrierCode = String.Empty;
string promptService = String.Empty;//used for temp storage
string serviceCode = String.Empty;
string boxCode = String.Empty;
string dryIce = String.Empty;
StringBuilder builder = new StringBuilder();
//call carrier class
string promptCarrier = CarrierPrompt.ShowDialog(oTrans,"Choose Carrier:", "Choose Carrier");
txtCarrierCode.Text = promptCarrier;
if(!String.IsNullOrEmpty(promptCarrier))
//switch on carrier and prompt service options
switch (promptCarrier)
case "F":
promptService = FedExServicePrompt.ShowDialog(oTrans,"Choose Service Option:", "Choose FedEx Service");
//Mutators : when service code ends in 0, change carrierCode to "G" and trim service option code.
if(!String.IsNullOrEmpty(promptService))
if(promptService.Length >1)
carrierCode = "G";
serviceCode = promptService.Substring(0,1); //trim the 0 off the code
builder.Append(carrierCode).Append(serviceCode);
else
carrierCode = "F";
serviceCode = promptService;
//MessageBox.Show(builder.ToString());
break;
case "U":
promptService = UPSServicePrompt.ShowDialog(oTrans,"Choose Service Option:", "Choose UPS Service");
carrierCode = "U";
break;
case "M":
promptService = MiscServicePrompt.ShowDialog(oTrans,"Choose Service Option:", "Choose Miscellaneous Service");
carrierCode = "M";
break;
case "C":
promptService = CourierServicePrompt.ShowDialog(oTrans,"Choose Service Option:", "Choose Courier Service");
carrierCode = "C";
break;
txtCarrierCode.Text = carrierCode;
txtServiceCode.Text = serviceCode;
//dry ice check,if yes, proceed to box class, if no, set boxCode to 00.
dryIce = DryIcePrompt.ShowDialog(oTrans,"Choose Dry Ice Option:", "Choose Dry Ice Option");
txtIceCode.Text = dryIce;
if(!String.IsNullOrEmpty(dryIce))
switch(dryIce)
case "Yes":
boxCode = BoxTypePrompt.ShowDialog(oTrans,"Choose Box Option:", "Choose Box Option");
builder.Append(boxCode);
txtBoxCode.Text = boxCode;
break;
case "No":
boxCode = "00";
break;
//set final ship via code field value here
txtShipViaCode.Text = builder.ToString();
public static class CarrierPrompt
private static DataTable dtCarrier;
public static string ShowDialog(object oTrans, string text, string caption)
Form prompt = new Form()
Width = 350,
Height = 175,
FormBorderStyle = FormBorderStyle.FixedDialog,
Text = caption,
StartPosition = FormStartPosition.CenterScreen
Label textLabel = new Label() { Left = 50, Top=20, Text= text };
//TextBox textBox = new TextBox() { Left = 50, Top=50, Width=400 };
//this is the combo for carrier
ComboBox comboCarrier = new ComboBox() { Left = 50, Top=50, Width=250 };
Button confirmation = new Button() { Text = "Next...", Left=50, Width=100, Top=75, DialogResult = DialogResult.OK };
Button cancel = new Button() { Text = "Cancel", Left=155, Width=100, Top=75, DialogResult = DialogResult.Cancel}; //TODO cancel key
confirmation.Click += (sender, e) => { prompt.Close(); };
// prompt.Controls.Add(textBox);
prompt.Controls.Add(comboCarrier);
prompt.Controls.Add(confirmation);
prompt.Controls.Add(cancel);
prompt.Controls.Add(textLabel);
prompt.AcceptButton = confirmation;
//call UserCodes adapter and filter it
UserCodesAdapter adapterUserCodes = new UserCodesAdapter(oTrans);
adapterUserCodes.BOConnect();
SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
opts.PreLoadSearchFilter = "CodeTypeID = 'Carrier'";
opts.DataSetMode=DataSetMode.RowsDataSet;
adapterUserCodes.InvokeSearch(opts);
dtCarrier = adapterUserCodes.UserCodesData.UDCodes;
comboCarrier.DataSource = dtCarrier;
comboCarrier.DisplayMember = "LongDesc";
comboCarrier.ValueMember = "CodeDesc";
//show user results and pass code ID
return prompt.ShowDialog() == DialogResult.OK ? comboCarrier.SelectedValue.ToString() : "";
//cleanup adapter
adapterUserCodes.Dispose();
public static class FedExServicePrompt
private static DataTable dtSerivceOption;
Width = 350,
Height = 175,
Text = caption,
ComboBox comboService = new ComboBox() { Left = 50, Top=50, Width=250 };
Button cancel = new Button() { Text = "Cancel", Left=155, Width=100, Top=75, DialogResult = DialogResult.Cancel}; //150, 75
prompt.Controls.Add(comboService);
opts.PreLoadSearchFilter = "CodeTypeID = 'FedExOpts'";
dtSerivceOption = adapterUserCodes.UserCodesData.UDCodes;
comboService.DataSource = dtSerivceOption;
comboService.DisplayMember = "LongDesc";
comboService.ValueMember = "CodeDesc";
return prompt.ShowDialog() == DialogResult.OK ? comboService.SelectedValue.ToString() : "";
//cleanup adapter
public static class UPSServicePrompt
Width = 350,
Height = 175,
Text = caption,
opts.PreLoadSearchFilter = "CodeTypeID = 'UPSOpts'";
//cleanup adapter
public static class MiscServicePrompt
Width = 350,
Height = 175,
Text = caption,
opts.PreLoadSearchFilter = "CodeTypeID = 'MiscOpts'";
//cleanup adapter
public static class CourierServicePrompt
Width = 350,
Height = 175,
Text = caption,
opts.PreLoadSearchFilter = "CodeTypeID = 'CourierOpt'";//notice no "Opts", too short for field length :P
//cleanup adapter
public static class DryIcePrompt
Width = 350,
Height = 175,
Text = caption,
String[] yesNoArray = {"Yes", "No"};
comboService.DataSource = yesNoArray;
public static class BoxTypePrompt
Width = 350,
Height = 175,
Text = caption,
opts.PreLoadSearchFilter = "CodeTypeID = 'BoxOpts'";
//cleanup adapter
