URL from button based on value of field
I know there are topics similar and I am not a coder but still learning.
I am trying to setup a button in AR Invoice Entry that opens a URL based on a UD field value.
I’ve added the UD field to the customer table and added a custom data view on the form but i’m unsure how to call the field from the data view.
// Custom code for ARInvoiceForm
// Created: 2/12/2021 1:11:07 PM
extern alias Erp_Contracts_BO_ARInvoice;
extern alias Erp_Contracts_BO_ARPromissoryNotes;
extern alias Erp_Contracts_BO_ARInvSearch;
extern alias Erp_Contracts_BO_ARInvcDtlSearch;
extern alias Erp_Contracts_BO_Company;
extern alias Erp_Contracts_BO_Customer;
extern alias Erp_Contracts_BO_Part;
extern alias Erp_Adapters_Customer;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
		this.epiButtonC1.Click += new System.EventHandler(this.epiButtonC1_Click);
		this.epiButtonC1.Click -= new System.EventHandler(this.epiButtonC1_Click);
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	private void epiButtonC1_Click(object sender, System.EventArgs args)
		Process.Start("https://" + "CustPortal_c");
Lesson 1: Rename your button to something other than epiButton1 (you’ll regret it later if you dont
To get a hold of a customer value you can use an EpiDataView
var myDv = oTrans.Factory("Customer");//Assuming Customer is the name of your Customer DataView
string url=(string) myDv.dataView[myDv.Row]["CustPortal_c"];
Process.Start("https://" + url);
That’s awesome, thank you Jose! It is indeed called Customer.
I knew i was missing something simple. This is super helpful and something I can use in other cases.
