Hello, I know I asked this before but we want to integrate UPS to epicor but not using the worldship module what do people suggest or companies that may be good for it ?
QuickShip from Epicor
Without quickship as it was really expensive
You said without WorldShip in your post. WorldShip from UPS is free. Any reason don’t want to use that either? We used that prior to QS and still use it here and there for the shipments that won’t work through QS.
Pre-QS days, we used to integrate Worldship via SQL to our ERP. That could be an option for you.
Here are two things you can investigate:
https://www.advancedware.com/EpicorERP10/AWUPSInterface.aspx
and also
